160 gas engine head gasket needed |
Hyperpack ![]() Bronze Level Access ![]() Joined: 05 Apr 2013 Location: 54806 Points: 65 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Aug 2018 at 5:58pm |
I need a head gasket for my H3 dozer with the 160 engine. One parts store in town cant get one, the other has to order from the factory. They claim the 149 and 160 have the same gasket, I thought the 160 had a few more headbolts. If someone has a gasket or part no. I would like to get the right one the first time.
Thanks Hyperpack
orangeman ![]() Orange Level ![]() Joined: 12 Sep 2009 Points: 1857 |
Hyperpack: Have this to offer: When I did my 615 engine - G 160 block top half I purchased a Gasket set:
Clevite VGS 6677 This included the following: 1 cylinder head gasket 1 Intake and Exhaust manifold gasket 1 Thermostat Housing Gasket 1 Thermostat Housing Seal 1 Valve Cover Gasket 4 Valve Cover Grommets or Push Rod Cover The Gasket kit list the following applications: Allis Chalmers 4 - G138, G139, G149 and G160 Obtained through NAPA - did not write down the price. All the best! Orangeman
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10823 |
Make sure it has the fire ring on it. HTH Tracy
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22015 |
Just use a 149 gasket.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5143 |
X2. That’s what I used on the turbocharged D15 series II (160) engine that I had been running. I only had one blow in nearly 20 years of pulling with it. |
