WD45 Starter |
Mark (ECIN)
Joined: 13 Mar 2024 Location: Hagerstown, Ind Points: 31 |
Topic: WD45 StarterPosted: 9 hours 19 minutes ago at 4:21pm |
How is the starter held on. Mine is loose, you can wiggle it around where it goes into the block.
When you start the tractor it moves.
dr p
Joined: 24 Feb 2019 Location: new york Points: 1687 |
Posted: 6 hours 57 minutes ago at 6:43pm |
Should be frictional fit in the housing with a set screw on the side
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 4023 |
Posted: 6 hours 54 minutes ago at 6:46pm |
There is a set bolt with a lock nut on the left hand side of the bell housing where the starter mounts. Loosen the lock nut and tighten the set bolt. It has a tapered end and fits into a corresponding tapered hole in the nose of the starter. Make sure that the bolt taper is in the hole and tight, as that is your main source of grounding for the starter.
Edited by Alberta Phil - 6 hours 54 minutes ago at 6:46pm |
