Two-Ten with 670I out of N5 Timing issues
ACD19farmboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACD19farmboy Quote  Post ReplyReply Direct Link To This Post Topic: Two-Ten with 670I out of N5 Timing issues
    Posted: 17 Sep 2026 at 6:19pm
Greetings, I should contribute more then swinging through occasionaly in a dire way! Two winters ago we started the project of putting a 670I (Gleaner N5) engine into a Two-Ten. Orginal engine had sat open to the elements for many many years. I knew we would run into things with the front plate. We pulled rockers and cam and changed plates ,the injection pump holes were machined exactly in the Two-Ten plate as though it was on the combine plate to use N5 pump. I have photos but it seems to be a struggle I will try to upload later. Anyways everything went together pretty smoothly. Untill we went to start it. Messed and messed with it and it would just run absolutely aweful. My friend who I purchased the project from said we might have the pump 180 off. Sure enough we were. We had only ran it a little while like this knowing something was off. Silly mistake. From what I understand this engine is the same as a 7080? The book says 22° we set it there but the engine kind of idles with some unbunt fuel but definitely starts to miss a little when you pick up the throttle. If you pin its ears back it sounds as though it picks them all up sounds like like a dang puller, full throttle it has the flutter/miss again. We have worked off and on on it for almost two years now. Never leaving the shop. Happen to have a little time and was just trying to get imput on what I presume to still be a timing issue. Is 22° BTDC correct? Thank you in advance.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2026 at 7:10pm
Whitch pump. Roosa or m100
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2026 at 7:19pm
Try 16 degrees on the Stanadyne pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACD19farmboy Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2026 at 7:21pm
Roosa Master
DM4629RY3761    2400
3248034    4036378
These are all the numbers from the pump.
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2026 at 8:21pm
Does it have Bosch Injectors? if so is the return line on the valve cover side? they can be installed a half a turn off, messes up the angle of the spray pattern and runs like crap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2026 at 10:26pm
The basic engine is the same as a 7080 engine if they were both built on the same day. N-5's were 1980 and newer, so it has the large piston pins and 3 ring pistons. The injection pump however isn't the same as a 7080 and is set at 190 flywheel HP like a 7060 would have been. Timing works best at 16 degrees BTDC. I believe spec is 18 degrees. Bosch injectors must be positioned with the return line facing the valve cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACD19farmboy Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 10:30am
I naturally new they were not identical but were close. I do not have a service manual for an N5. So 7080 was what I thought was needed to go off of. Thank you for the information of the book saying 18° for this engine. I have rolled it around to 16°. Started it up and it seemed to maybe idle better but picking up throttle it definitely ran even worse. I looked at the injectors and the return lines face the valve cover. Last year before we realized we were 180 off on the pump I purchased rebuilt injectors from Spencer Diesel. The injectors were for the Roosa pump. After putting them in we realized the pump was way off. I also got a salvage front crank pully from an 8070 because the combine pully only had one belt groove. I need to recheck to make sure those marks are the some. I cant imagine the pullys be timed different. I'm hoping there is still something we are over looking. Would the pump need rebuilt? It had sat for a number of years but not terribly long.
Thanks again for everyones input.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 10:53am
You could get it ran on a test stand. Thet would prove it's worth. It couldn't hurt to have it rebuilt but....
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 11:53am
Did you put a new torsion damper on the 8070 pulley
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACD19farmboy Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 3:42pm
I did not put a new damper on. The salvage one looked good and the N5 one also looks good. From my understanding when I was reading into these, that if I needed one they were hard to come across and no longer made. Maybe one for a Detroit Diesel would work if I remember reading correctly. I wouldnt think a faulty damper would cause it to run bad. Just if faulty would cause vibration damages long term. Does the characteristics of my description seem usual of a failing injection pump? Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 4:14pm
I have a 8070. 3 actually. One got a knock in the lower crankcase area. Sounded like a rod knock. Its fwa so i had to move the front axle out to get the oil pan off. Pulled the rod caps. Nothing wrong with the nearings. Then i was stumped. After much discussion on the forum someone suggested the damper might be bad. Put a new one on it and fixed it. Bob King at reliance works can get you one. Theres a heavy oil and a weight inside. The oil hardens up over time and causes thw weght not to move. That causes torsional deflections in the crankshaft. It wiil cause it to run bad because it makes the head on the injection pump jiggle around. If it goes on long enough it has been known to break cranks. It will be around 700.00 if they havent gone up. I think its cheap insurance
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 37 minutes ago at 10:55am
No OEM's available. Vibratech still supplies them. One for a 4-71 Detroit is it. Has been past posts on here about them including part #. Yours is old enough I'd replace it regardless.
Edited by SteveM C/IL - 12 hours 36 minutes ago at 10:56am
