Trouble with the M3 |
plummerscarin
Topic: Trouble with the M3Posted: 24 Oct 2026 at 4:26pm |
Chunked a bearing on the main shaft and I see the bearing housing is cracked
Is there a trick to removing these pulleys?
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 937 |
Posted: 24 Oct 2026 at 5:08pm |
Ive got a L3 that looks just like that and ive had that pulley off to put bearings on the main shaft. I didnt have any problem getting it off. If you decide to use heat id be very careful with it. I dont know how much heat the laminations in that header clutch coil will stand
Good luck |
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
plummerscarin
Posted: 24 Oct 2026 at 5:54pm |
My assumption is after removing three bolts off the main pulley, it would just pop loose. The 3 jaw puller has a lot tension at the moment. Figured I could heat near the center if that's all it takes then tackle the clutch. I know a guy near Preston, may have bearing housing
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2562 |
Posted: 24 Oct 2026 at 6:45pm |
Screw the 5/16s bolts that you took out into the other holes and it will push off quite easily. Blow the holes out first, plenty of lube, and alternate the tension.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 9264 |
Posted: 24 Oct 2026 at 10:22pm |
Lynn has your answer. My F2 is like that. Once you figure it out it's a breeze. Probably in the service manual which nobody has....
The engineers were thinking. When i do a mainshaft brg, I do both sides. That other one has as many hrs on it. When I got my 4000hr R62 I wish i'd sent it to the shop for PM and had new main brgs installed. A couple years in it ate the rt side and of course spun on shaft and ruined it. Would have been half price or less. Think that shaft was around $3500.
Edited by SteveM C/IL - 24 Oct 2026 at 10:32pm |
plummerscarin
Posted: 24 Oct 2026 at 11:50pm |
Kinda wondered if that was case. I did try that but bolts didn't seem to do anything. I'll clean it out good and try again. Thanks |
Michael V (NM)
Posted: 25 Oct 2026 at 11:01am |
I would use sacrificial bolts to pull with,, or better yet,, new ones when ya go back together
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3276 |
Posted: 25 Oct 2026 at 12:11pm |
To push with I'd get grade 8 bolts and grind the ends off just a little so when they mushroom it won't be an issue backing them out
plummerscarin
Posted: 25 Oct 2026 at 1:05pm |
So this morning we went back and blasted some air into all the holes and sure enough there were threads to engage in as Lynn had stated. Lube and sent the bolts in. Got really really tight. My thread chasers aren't long enough reach in and I thought they were bottomed anyway. Mind you the 3 jaw is still in place. Next I brought out the torch and gave it 3 heat cycles. Went and picked up walnuts for while allowing it to cool. Began the tightening sequence again along with the 3 jaw and all were really tight again then noticed one bolt turning more than the others when POP!! The whole works jumped off and hit the ground. This is a tapered hub and bushing assembly. On closer inspection, two bolts never passed through .the hub. The threads were not clean enough. Now down the inner hub and need a different puller.
Back at it after lunch |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 36763 |
Posted: 25 Oct 2026 at 1:16pm |
Lynn Marshall
Posted: 25 Oct 2026 at 9:16pm |
Once the magnet and armature are removed, I just used a pair of 1/2 inch redi rods and a plate to pull the small header drive pulley off.
plummerscarin
Posted: 25 Oct 2026 at 9:19pm |
Could not find my bigger puller. Made do with current setup
![]() Busted housing and outer race pried off easy enough but that inner race pushed my buttons. Hot wrench finished it. Against my wishes we proceeded to remove like assembly from another M3 we have. Knowing what we know now, not nearly as much effort to remove. Currently at the main bearing and good housing. Building a different puller to use the threaded holes in the housing to pull. Family stopped by for visit so we got squirreled. Will resume tomorrow |
plummerscarin
Posted: 25 Oct 2026 at 9:22pm |
Lynn, yes I considered that but didn't want to stop and fab something. In the end that's what I'm doing for the housing. Will update
plummerscarin
Posted: 26 Oct 2026 at 7:26pm |
Found a piece of 1x3 iron 7" long to use for my puller. This only accommodates two of the four four bolt holes in the housing. I a piece of 1x3 tube iron for the other bolts. Drilled the needed holes cut the needed all thread and proceeded to pull. The tube collapsed and the other two all threads stripped in the nuts. Shut down till I get more all thread and better chunk of iron. Or, buy another housing my parts guy found. Pretty pricey IMO but maybe concede defeat
plummerscarin
Posted: 29 Oct 2026 at 7:53pm |
So I tucked tail and got the housing from my parts guy. And a new bearing. Putting it back together. On the tapered hub and main pulley is there a torque spec for those 3 5/16 bolts? Pretty sure they need evenly tightened
Some general charts I'm reading have it at 17ft/lb for grade 5 dry Edited by plummerscarin - 29 Oct 2026 at 7:57pm |
8070nc
Posted: 29 Oct 2026 at 8:02pm |
A online torgue chart should give you a spec for whatever grade bolts they are. That shoukd get you close enough. Since its a taper i think id check them again after you run it a little
1984 80780
SteveM C/IL
Posted: 29 Oct 2026 at 9:14pm |
antiseize and a 6 in 3/8 drive ratchet will get you all you need.Just good and tight for a 5/16 bolt. They will not loosen and will hold just fine.
Lynn Marshall
Posted: Yesterday at 3:48pm |
It's rather amazing that those 3 little bolts that hold the big pulley onto the tapered hub are literally driving the whole machine. The tapered hub is keyed to the shaft, but the pulley isn't keyed to the hub. I've never seen a failure of that design on the gleaner.
TramwayGuy
Joined: 19 Jan 2010 Location: Northern NY Points: 11992 |
Posted: 21 hours 59 minutes ago at 12:08am |
“..antiseize and a 6 in 3/8 drive ratchet will get you all you need.Just good and tight for a 5/16 bolt. They will not loosen and will hold just fine.”
Do NOT use any antiseize on the taper surface. You can split the sheave hub. (Ask me how I know) |
plummerscarin
Posted: 21 hours 30 minutes ago at 12:37am |
As noted earlier the 3 bolts used the disassemble the hub never really worked. They seized in the pusher holes. The 3 jaw did all the work. Anyway, tonight I went to reinstall the taper assembly and sure enough broke one the bolts broke off. Rather than fight that I took the one from our other machine. I installed it dry. It is all back together and running and seems more quiet. Or it's my imagination. We only run this a few hours a year, came to us used and any problem it has sometimes go unnoticed til something catastrophic happens. In this case, something did sound wrong, was the back of field, stopped and got out to look but couldn't see anything wrong. Cut my way back to the front, unloaded the bin and that's when the bang happened. A service manual would have been helpful but hard to find. I think the take away for this project is making sure the holes for the pusher bolts are clean and lubed and it takes a mighty stout puller for that shat bearing. I'll post photo later of the failed one I made. Now waiting for dry weather
Thank you for all the input |
Posted: 17 hours 47 minutes ago at 4:20am |
#1. Always use a tap, a can of WD40 with a stinger, compressed air and an air blow gun to get those holes really clean and lubed up. #2. New bolts and I always use grade 8 when replacing them. #3. Even tightening of those bolts when disassembling and assembling even down to just a very little at a time. That tapered bushing was a wonderful design, but also has its quirks.
plummerscarin
Posted: 13 hours 55 minutes ago at 8:12am |
That is why I asked for a torque spec. I went around the hub a half dozen times before before the bolts stopped turning at 18ft/lb. I prefer a spec over going by feel
My mistake was assuming compressed air and WD40 was adequate to clear those threads Edited by plummerscarin - 13 hours 47 minutes ago at 8:20am |
8070nc
Posted: 13 hours 23 minutes ago at 8:44am |
I never did it on mine but i think a torque wrench on those bolts is a good idea. Ive been working with taperd bushings in sprockets and pulleys for years in meat and rendering plants. I never used a torque wrench on any of those because it was always hurry up hurry up so we can start back up. Instead of a wide variable feel you have a instrument reading or click
1984 80780
Posted: 13 hours 15 minutes ago at 8:52am |
Those threads get so rusty they always need a tap.
SteveM C/IL
Posted: 5 minutes ago at 10:02pm |
Not to mention the bean fuzz and everything dirt that collects....
