Disc harrow
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Topic: Disc harrow
    Posted: 3 hours 41 minutes ago at 4:15pm
Finally stirred some dirt with my D 15 today. It ran well. Did find the discs on one gang are turning independently. Guess I'll have to pull that axle and get it built up and square? Since the damage is already done, it can run as is a while. Always something. Thanks
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 31 minutes ago at 6:25pm
They need to be tight. Square has nothing to do with it really. I have 9 inch spaced primary tillage offsets one IH one JD both have round axles. I a Harbor Freight cheapy end wrench to bind against the frame on one end and 3/4 ratchet and 3 or 4 feet of pipe. Then I switch to a breaker bar and six or 7 feet of pipe for several more turns. And sometimes that will loosen up after a day bouncing over rock ledges, and need another round of tightening.
Of course taking it all apart and wire brushing blades and spacer faces, so no rust helps keep things tight too.
