7060 hydraulic leak
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Topic: 7060 hydraulic leak
    Posted: 12 Sep 2026 at 7:04pm
On the very top of the rear of the powershift transmission in my tractor there is a steel line that goes from there down around and rear to the hydraulic center of things between the lift arms, I can get a wrench on both ends. The line supplys the fluid to raise and lower the lift arms. Leak is at the transmission top union fitting. Leak comes from around the sleeve that goes into the nut of the steel line. I've replaced the rubber O ring on the union fitting and am confident its not leaking there. I've used my 60x maginifer and cannot see a crack in the female flare of the steel line. . Iam asking what are the odds of the union male is the problem, AGCO part # 70923080. Or #2 give up and make a rubber line? What is the PSI here? Thanks for any help.
Edited by whatscooking - 12 Sep 2026 at 7:15pm
68 D21 81 7060
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2026 at 7:55pm
In theory it can go to 2500 or whatever the pump is set at. It will vary according ti the load on the 3 point hitch. Alternatively if you are running a big plow or ripper or something like that on traction booster and hit a hard spot it can go to 2500 for short periods
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2026 at 8:00pm
From zero psi to 2500 psi. With nothing hanging on the 3pt hitch it will be near zero psi. With the hitch fully raised and nothing on it, the number should still be near zero. The hitch shall NOT be adjusted to come up 100% !!!! So, if you have a leak with the hitch fully raised and then the leak subsides when let down a few inches, it is a pressure leak and probably the flare on the line. Make a hose and I always go around the left side instead of the way they routed it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2026 at 5:10am
I'm needing a shop manual,I have many questions.
The previous owner slipped in that the tractor needed one of those darn double seals so I guess I found it. The metal cab floor had some old duct tape so someone was in there awhile back, quite the mess. I figure someone has went ape on the fitting and distorted or cracked it.
Looks like I'm going back to my Massey dealer to make a hose.
Edited by whatscooking - 13 Sep 2026 at 5:32am
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2026 at 6:31am
You don't need a shop manual to verify if the hitch is coming up 99% or 101%.   Engine running and hitch fully up, you should be able to (with a strong back) lift on the hitch and make the upper lift arms go "up" another inch or two. That would be correctly adjusted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2026 at 7:31am
Comes down to what my guy will charge to make this and getting fittings and length correct but I came up with a AGCO rubber hose in a bag made for it but by the time they ship $90.00.
Dr Allis do you by chance have a Pic how you routed yours or tell me which direction you went, over top or around front or the back? I looked at mine and a 90° will be needed at the valve. Curious why not go the same route?
Edited by whatscooking - 13 Sep 2026 at 7:48am
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2026 at 7:33pm
I came around the left side and around the back. Easier to route and takes a 90 degree on each end. I've also had several 3pt hitch corn planters with lift assist wheels over the years. Making this hose allowed me to place a TEE in it somewhere with a hydraulic hose connection so the lift assist wheels could be plugged into. Thus pull on the 3pt lever in the cab and the lift assist wheels will work in harmony with the 3pt hitch arms.
Edited by DrAllis - 13 Sep 2026 at 7:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2026 at 3:50am
Cut the steel line out in three pieces, found a crack in the flare. So while iam going to the store what size of a hose is the fuel line that goes between the fuel filter and the electric pump. Once again someone when they replaced the electric pump got the 90° inlet pointing wrong and has kinked the hose which looks pinched shut and leaks at hose the clamp.
Edited by whatscooking - 14 Sep 2026 at 4:10am
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2026 at 3:53am
Got the new line fished into place so backed her out and washed down again. Tested out on the hill drive i have no drips.
Next up. Decided to remove the auxiliary fuel tank. Don't need that extra fuel for what iam doing and the crossover looks about to snap and I want to see what's behind there to clean and insepct. Came out easy enough. What a sludge pit behind the tank. It had that hydraulic line leaking for awhile. Fuel line up to filter looks OK but might as well change that 1/2 "line while drained. What a octopus conglomeration at the electric fuel pump/primary filter aera. Line going from filter to electric pump to is so kincked and deteriorated/oozing surprises me the engine even runs.
Ow well, looked online and can buy what ever length of fuel line ya want but I dont trust it. So back to a different dealer today,apparently John Deer doesn't use a 1/2 fuel line, I asked yesterday while getting the hydraulic line and no 1/2 fuel line there, or Autozone or Advance. My Massey guy or NAPA then.
Edited by whatscooking - 15 Sep 2026 at 4:13am
68 D21 81 7060
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2026 at 1:41pm
That’s an Excellent idea / engineering and also extremely simple for operators right hand during headland turns. Thanks for sharing DrAllis.
