8010 low pressure hydraulic line
PawPaw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PawPaw Quote  Post ReplyReply Direct Link To This Post Topic: 8010 low pressure hydraulic line
    Posted: 31 Aug 2026 at 11:32am
Where is the best place to plumb into for return line on sprayer with hydraulic pump?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2026 at 11:55am
A "case-drain" line ???   There are two hoses on a sprayer pump (in and out) and this is the third line/hose??
Post Options Post Options   Thanks (0) Thanks(0)   Quote PawPaw Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2026 at 12:08pm
Only 2 lines to hydraulic motor pressure and return. Sorry for not being clear. Sprayer manual says best to not hook return line to remote coupler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2026 at 12:37pm
#1. Remove lower sight glass and adapt an O-ring fitting into that hole and check your oil level using the top sight glass. #2. Plug in your second hose to the other remote valve and place that valve in FLOAT and wire it into float so it can't be bumped into HOLD.   #3. Remove the steel plate under the PTO gears and above the drawbar and drill/tap a connection into that plate with a coupler to plug your hose into.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PawPaw Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2026 at 1:01pm
Thank you
