American made ball valve? |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 11105 |
Topic: American made ball valve?Posted: 27 Aug 2026 at 4:29pm |
I need some American made 1/8 ball valves for gasoline cut off. Can't find any made here. I hate to use the China stuff? Anyone have a good supplier? Thanks, Tracy
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 93360 |
Posted: 27 Aug 2026 at 4:39pm |
90% of the APOLLO ball valves are made in the USA... not sure about the sizes.. Check them out...
AveryD12
Joined: 05 Mar 2018 Location: Foxworth.MS Points: 200 |
Posted: 27 Aug 2026 at 9:46pm |
I asked Chatgpt and they list a couple valves that meet your needs. Both are 1/8” FNPT x MNPT.
Connector Specialists – St. Rose 175 James Dr E, St. Rose, LA 70087 504-469-1659 Parker distributor Ask for Parker MV708-2 Parker's specification: 1/8" male × 1/8" female, brass, PTFE seats/seals, 500 PSI Below are online distributors: Wilson Company currently shows the MV708-2 at about $13.98 each with 18 available. The Hope Group shows about $14.97 each with 18 in stock. Bernell Hydraulics is particularly interesting because its listing explicitly says the MV708-2 is intended for “Fuel Line Shutoffs for Gasoline and Diesel Equipment” and lists agriculture as a target market. HTH |
Tracy Martin TN
Posted: 28 Aug 2026 at 3:32pm |
I will check them out. Thanks, Tracy
AveryD12
Posted: 28 Aug 2026 at 6:04pm |
