CA Hydraulic Cylinder Leak
dfwallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dfwallis Quote  Post ReplyReply Direct Link To This Post Topic: CA Hydraulic Cylinder Leak
    Posted: 05 Aug 2026 at 7:06pm
I had the cylinders repacked a year ago.  I was told I'd need to peridically tighten them up until the material compresses.  The right one has stopped leaking but the left one seems to refuse to stop leaking.  It doesn't leak on the up stroke.  It seems to only leak at the point where the pressure is released (from hold).  Perhaps the bouncing implement pressure when in hold causes additional seepage around the piston?
1952 CA13092, CA Pickup Plow, CA Cultivator, CA Two Row Planter, Dunham-Lehr GC78 Disc, Grader Blade, 3pt Fm180 Finish Mower
