WD Leak Hose Bracket Mount |
Too Tall
Topic: WD Leak Hose Bracket MountPosted: 24 Jul 2026 at 10:56am |
My WD leaks oil out of the four bolts that attach the hose bracket to the top of the hydraulic pump. I put on new copper pressure washers and they still leak. When I raise the hydraulic lever it leaks so much as to make the hydraulics unusable. Thanks for help in advance
Too Tall
Posted: 24 Jul 2026 at 11:05am |
I should of said under the hose hook up part. Those 4 bolts do not attatch the bracket.
DrAllis
Posted: 24 Jul 2026 at 11:58am |
There is an O-Ring between the hold valve on top of the pump and the pump body. Twp bolts to remove the hold valve.
