Canopy or tilt up door on lean to |
1951WDNWWI
Bronze Level Access
Joined: 11 Jul 2011 Location: NW Wisconsin Points: 135 |
Topic: Canopy or tilt up door on lean toPosted: 26 Jun 2026 at 12:30pm |
Anyone do a canopy or tilt up door on a lean to? I have 15 ft 6 inch by 8 ft 4 inch high openings I want to close in winter with the picnic tables and other thinggs stored. A sectional garage door 8 feet tall does not work because the inside is just over 7 feet deep. Probably be a do it yourself design since you see very little of these doors in the US.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 93506 |
Posted: 26 Jun 2026 at 12:51pm |
you got room for a SLIDER ?? two doors 8 ft wide that overlap 6 inches would work... and you can build yourself out of 2 x 4 frame and 1 x 6 or plywood face.... have seen some use roofing tin on the face also..
Edited by steve(ill) - 26 Jun 2026 at 12:52pm |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42508 |
Posted: 26 Jun 2026 at 3:46pm |
Son built a 10 x 10 door that swings up and becomes a extension roof into shop . Hinged at top and has slides inside to hold open - only problem it needs to be raised from inside
