D14 Fuel valve stem
Tractor Tech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tractor Tech Quote  Post ReplyReply Direct Link To This Post Topic: D14 Fuel valve stem
    Posted: 20 May 2026 at 9:54pm
New to the forum and want to find out what seals the valve stem on the fuel bowl. Previous owner used Teflon tape, but there is no sign of an oring or other type of seal. Does it use an oring to seal?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2026 at 10:05pm
teflon tape or wax string, etc.... is a good fix.... you can add more as needed for a good seal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2026 at 1:07pm
I used some waxed dental floss...all i had available
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2026 at 4:54pm
Graphite cordage is what is used. HTH Tracy
