AC6089 Block Heater Remove and Replace |
REM
Joined: 25 Nov 2021 Location: USA Missouri Points: 22 |
Topic: AC6089 Block Heater Remove and ReplacePosted: 25 Nov 2021 at 2:38pm |
I recently purchase an AC6080. The Block heater is bad and I purchased a new one from Countryside Tractor. But, due to the design of the pipe to the oil cooler I am not able to remove the old Block heater. Any suggestions? My first thought is to cut the tube going to the oil cooler and then run a rubber hose form the new heater to the oil cooler (the new heater is a slightly different design in that it only has a short stub for the oil cooler line).
DougG
Posted: 25 Nov 2021 at 7:32pm |
Yeah Ive dealt with those and the last thing I thought was - do i gotta split this thing to get a new one in , lol- quite a design- i have cut the tube and used as much of it as i could then used high temp rubber hose to connect,
Alvin M
Posted: 26 Nov 2021 at 7:28am |
Cut old tube off and use part of it to fit to oil cooler hook up with new hose in kit
