CA Starter
JD-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JD-Ohio Quote  Post ReplyReply Direct Link To This Post Topic: CA Starter
    Posted: 16 Sep 2020 at 3:12pm
Do the CA's and the C's use the same starter?
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2020 at 3:50pm
Yes
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2020 at 7:43pm
NO, they are not the same starter. However  they will work as a need to get by. The C and early B tractors have the switch mounted on the bottom of the starter. The CA and late B tractors have the switch mounted on the top of the starter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2020 at 7:52pm
Internals are the same....
Steve@B&B
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2020 at 10:51pm
my C starter and CA starter had differant bendix gears the AGCO dealer said you could flip the nose cone when he pulled out of the box it was totaly differant. after some research there were two differant starters for the C my 1943 took a nolonger avaliabe starter. i took it to an old use to be AC guy he rebuilt it from parts in his shop.
This page was generated in 0.143 seconds.
