More parts questions
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: More parts questions
    Posted: 12 Jan 2020 at 10:08pm
Hi everyone, have some more questions on a few things
First does anybody have parts book on rotary mower handy. Have a few spacers or bushings
If you could look in book and see if they might be 538125.
Second is this cover and the tag has 255674 on it, and that number isn't in numerical book.
Thanks for the help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2020 at 10:24pm
We also have this start switch and on it 226126. That number isn't in book. But 226128 is saying switch. Is that the same
Thank you
Edited by Mikez - 12 Jan 2020 at 10:26pm
TOM (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TOM (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2020 at 3:32pm
Bushing fit mower 160 &170, heavy duty blades. Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2020 at 10:17pm
Thanks tom, could you see where this 537846 is in the rotary mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote TOM (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 10:33am
537846 bushing (.890 I.D x 1-1/2 O.D. x 13/32 thk)  is for use with the standard shredding blades (537845)   Tom
stu(ON) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stu(ON) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 1:27pm
1951 WD original starter switch.  You be the judge.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 1:37pm
That Switch Is Part # 70222880 For The Autolite Starter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2020 at 9:54pm
Thanks again. The bushings are available if anybody is interested
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2020 at 12:44pm
Mike-
that starter switch in your picture is for a delco-remy starter, and since it is cast aluminum, not stamped steel, it should be worth 2x what they get for the modern stamped steel switch boxes.
www.awtractor.com
A&W TRACTOR 920-598-1287
VCaporuscio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VCaporuscio Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jun 2020 at 3:45pm
Any idea where someone can get those 537845 blades?
