What Implement lift cylinder will work
Krazy Karl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Krazy Karl Quote  Post ReplyReply Direct Link To This Post Topic: What Implement lift cylinder will work
    Posted: 23 Apr 2019 at 9:30pm
Guy i know bought a WD45. Then bought i think 8 ft pull type disc. He asked me what cylinder he should get to lift the disc i said that i didn't know exactly what to get but did tell him its a high psi low flow system. So the question is what cylinder will work the best for it. Just the factory outlet on the back of tractor. Thanks
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2019 at 10:37pm
Get a 2 inch if you can. Bigger cylinders are too slow. I have used a multitude of cylinders behind many different WD's and 45's and never had problems. Other people have, I haven't.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2019 at 4:41am
3500psi, @4gpm...Wink
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2019 at 6:21am
1.5 or 2" would be good.  They do make 3,500 psi or so, so make sure it's a good cylinder and hose.  I've stroked them out before and never blown one up, but...it could happen with a cheap setup.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2019 at 7:41am
2 inch diameter is about as big as you'll want or need. If you don't let the cylinder get 100% stroked out and let the pump hammer on it, you'll never reach 3400 psi, so no problems.
modirt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2019 at 8:07am
Did AC tractors come with a remote cylinder or did they have to be purchased separate? The D15 I found had one, but not sure of it's origin. Out of all the comments and references to AC equipment, the original AC cylinders designed for the higher psi are rarely, if ever mentioned, and to my recollection, rarely seen. I would think folks would be after those.
As a kid growing up, all our tractors......different color.....came with a cylinder and cast iron hanger bracket on the back to carry it with you at all times. For the first decade or so, we only used that one cylinder. Change from a disc to a planter and you took the cylinder off and kept it with you. Later on, as equipment got bigger, each piece of equipment came with it's own dedicated cylinders. More convenient, but also more expensive way to go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2019 at 9:09am
Pretty sure the remote cylinder was an OPTION, as some people had no need for one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Krazy Karl Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2019 at 9:23am
Thanks for the help.
