auction last week, 7020,200, and more
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Topic: auction last week, 7020,200, and more
    Posted: 21 Apr 2019 at 10:20pm
NW of Lubbock TX, at Cotton Center
7020 and 200 looked OK, but engines were TIGHT, or I couldn't get them to turn, been parked several years, 200 had very weak rear tires, seat gone, factory air cond.,
7020, fellow said the engine was overhauled not long before it was parked, drawbar missing,
they were definitely projects or parts....more than I really wanted..
7020  $1500.00
200  $1350.00
1350  field cultivator/trash rakeEvil Smile 28' $200,,,
I think the 2500 disc went for $200-225,, not sure, needed new blades, the ones on it were prolly less than 18-" or so.........
I  think if I was to have got one,, it would been the 200,, although, I like the 7020 too...just TOO many unknown things with either....just more 'project' than I want right now..
 oops,, I forgot, there was a restored G, with cultivators(not restored) $5300, one that I talked to said it came in a box, the FFA restored it...
Edited by Michael V (NM) - 21 Apr 2019 at 10:55pm
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 6:35am
I would like a 200 like that. Factory air would be nice. Would assume it had 3 pt hitch, dual PTOs, and hydraulic PTO clutch. Darrel
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 6:43am
If the 200 had a good grille, that would be $600 alone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2019 at 9:17pm
Yes Jay, the grill was decent, had one small ding in the screen part
yep, Darrel, had 3-pt, dual speed PTO, not shue about hyd engage, had the long lever to the left side of the chair..
PeteMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeteMN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2019 at 9:58pm
Not that bad looking for Texas.  Both look like they're worth fixing.  Trouble is the cost to haul them north is probably more than what the tractors are worth.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2019 at 10:13pm
Pretty good looking tractors for the prices, but like you, I don't need more projects (or tractors).  The G sure brought a good price!
Have you gotten much moisture down in your country Michael?
Allis Express participant
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2019 at 10:28pm
Looks like the 200 I bought several years ago in Abilene, TX for $1500 except for the long axles and the weights. The owner could not get the power director to engage. I winched it on when I realized the diverter valve was stuck, but did not want the seller to know. I drove it off the trailer at home. Some times you had to turn the steering wheel to get it to work. I used it for several years before I had to rebuild the pump. Did great for years until a plate in the PD broke.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2019 at 10:33pm
There is a 7020 locally I plan on looking at locally. Been setting 2 years. He wants $2500. Seller says it has starter problems.
Don't tell my wife. She thinks 16 tractors to be excessive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2019 at 6:26am
long lever to the left side makes it a non-hydraulic PTO clutch. Hydraulic PTO clutch has the lever on the right side of the seat, on the side of the counsel. Kind of odd that it has lots of nice options, then falls short of having the hyd PTO clutch. Darrel
