7020 A/C
joe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joe Quote  Post ReplyReply Direct Link To This Post Topic: 7020 A/C
    Posted: 21 Apr 2019 at 9:04pm
I have a 7020 that the a/c isn't working on. The high line from the compressor to the condenser gets very hot and no cooling action takes place. I suspect that the TXV is plugged. I plan on replacing that and the R/D, as well as all o-rings.
    It already has a Sanden compressor, and also has a temp switch on the outlet of the condenser. I would like to go to 2 pressure switches w/ the deicing switch. Is that an option. If I can do it without the spacer adapter, better yet.
