175 tach
cnafarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cnafarms Quote  Post ReplyReply Direct Link To This Post Topic: 175 tach
    Posted: 21 Apr 2019 at 1:21pm
Does anybody know where the tach cable goes on an Allis 175 diesel. The cable was unhooked and missing from mine and I’ve got no idea where it connects to. It has an alternator like 3 wire delco on it. Thanks for any and all help
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2019 at 1:25pm
The original Alternator had a drive shaft off the back from the main alternator shaft, then there was a gear box that attached and the cable connected there. My 180 is similar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cnafarms Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2019 at 4:08pm
Well this has been changed out or replaced anyway I can retro fit something in then
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2019 at 7:33pm
As said, alternator should have a tach drive with 3 screws that attach the drive cable. That needs to be removed when replacing the oil filter. It would be cheaper to buy the correct alternator if not already on it. Another option is to a magnetic drive.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 9:41am
Here is what you need.  DJs sells alternators with the drive coming out the back.  The one on my 175 had been taken off 20 years ago, but stumbled across it when cleaning out the barn some years ago.
