Spring a door back |
whatscooking
Topic: Spring a door backPosted: 12 Aug 2026 at 5:28am |
I have done my share of, make her take her, but before I try to get the lower door back in place, not real far out, any tips appreciated.
81 7060 |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 11101 |
Posted: 12 Aug 2026 at 1:52pm |
Patience and gentle correction. Depends on where the sprung area is, go slow, might use shims to push against at proper place.HTH Tracy
Posted: 12 Aug 2026 at 2:27pm |
Those doors oftentimes crack just above the door latch area. A horizonal crack that connects to the vertical structure that goes to the front/top of the door frame. I've welded/braced many over the years.
Joined: 11 Sep 2009 Location: illinois Points: 93259 |
Posted: 12 Aug 2026 at 3:15pm |
i just worked on a big Case cab that they had the door open and hit a tree while mowing.. Bent the door about 10 inches out... I took the door off and cut the weld and rewelded the area like Dr mentioned.. Thought it was close.... Took the door back and it was about 3 inches off at the top... Mounted the door, put a 2 x 4 between the door and frame at the latch and used a small comealong on the TOP of the door, thru the cab, to the opposite side frame.. winched it a couple times until it fit the latch pretty good.. They actually popped the top window out when it hit the tree..
Edited by steve(ill) - 12 Aug 2026 at 3:16pm |
SilverShoes
Joined: 20 Feb 2014 Location: Seneca, Kansas Points: 228 |
Posted: 12 Aug 2026 at 3:38pm |
I’ve seen a Buddy twist car doors back using a block of wood as a wegde. He told me always try to reverse the twist the way it got twisted. He said he straightens frames the same way. He pulls it out the way it went in.
whatscooking
Posted: 8 hours 16 minutes ago at 6:09pm |
Sure enough there is a horizontal crack. Expecting alot of that thin metal there. Little piece of angle on the outside? |
68 D21 81 7060
Posted: 8 hours 10 minutes ago at 6:15pm |
I always tried to peel back the rubber seal and make repairs on the inside.
whatscooking
Posted: 7 hours 53 minutes ago at 6:32pm |
Take out the window? |
68 D21 81 7060
Posted: 7 hours 20 minutes ago at 7:05pm |
If that's what it takes, yes.
