HD6E starter motor |
Dozer987
Joined: 08 Aug 2023 Location: West Almond, NY Points: 32 |
Topic: HD6E starter motorPosted: 29 Oct 2026 at 5:11pm |
It has been a year since I posted about my starter motor troubles. I rebuilt my starter and starter solenoid. I replaced the wire connecting the batteries with #2 welding cable. I used #2 wire on my HD6G that has both batteries in the same battery box. I got back to the HD6E and hooked up the wires to start it. The left hand battery box smoked and the connecting wire came off the terminal end. I replaced the wire checking that all connecting cables were tight. I pressed the starter button again and the right battery box smoked melting the terminal connector. I replaced the #2 cable with the #0 cable with the keyed battery disconnect under the seat. I turned the key and the starter solenoid clicked without me pressing the starter button. I turned the disconnect off but it didn't go off. The battery cables got warm. I loosened the terminal ends. I could rotate them but I could not remove any of them. I had to spread them with a screw driver because the heat reduced the battery terminal diameter. I recharged the batteries and found the year old batteries could only hold 25% charge. My $25 replacement battery disconnect came today. Rating 200 Amp continuous 1000 Amp intermittent. Hope it goes well when I try to start it tomorrow.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42507 |
Posted: Yesterday at 9:55pm |
Almost sounds like one battery is reversed on polarity ?
believe a 24 Volt system to starter using 2 - 12 volt batteries If your getting a dead short (it seems) need to check all wiring closely
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 5025 |
Posted: 10 hours 11 minutes ago at 12:04pm |
Not sure of the age of a HD 6E, but probably old enough it left from the factory with 2, 6 volt batteries. So a 12 volt system by using batterers in series. So if using 2, 12 volt batteries today you want them in parallel.
Les Kerf
Posted: 6 hours 55 minutes ago at 3:20pm |
I did a quick google search and came up with several references indicating that this tractor had a 24 Volt starting system. I have never so much as touched any HD6 crawler myself.
