Hd6 wet clutch pump
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2026 at 4:48pm
I recheck today and have oil pump and part number is 623316 and she is 7\16 inch longer .
Primos75 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Primos75 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2026 at 6:42pm
I wonder what the difference is on that one? Does it have more then 2 ports? Wonder why it's longer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Primos75 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2026 at 7:05pm
That part number i think is from a m45 motor grader. At least that's were i found it. Whether or not it would work i have no clue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2026 at 7:59pm
This pump came from HD11 dozer and have 2 hole for oil. 1 in front and 1 on side and look 3\4 inch hole and I open and loog very good condition
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Posted: 23 Apr 2026 at 9:09pm
Re "That part number i think is from a m45 motor grader"
I'm not near our AC Forty Five grader or the books
IIRC the only hydraulic pump on them was for power steering.
I might get a chance to look tomorrow.
Incidentally Australian versions of that grader had model number "524/****" and the pump was Hydreco
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2026 at 10:07am
Originally posted by HD6 Merv HD6 Merv wrote:
Master clutch oil pump is only a circulating lube pump. And oil pressure is only around 20 psi.  I know this because ive seen some late 40M series HD6 that had a clutch pressure gauge fitted in the dash...
Apparently I misunderstood the function of the pump; it really doesn't assist in actuating the clutch, but rather is only to facilitate circulating the oil for the purpose of filtering and as an aid to cooling?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Primos75 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2026 at 11:45am
That sounds about right from what I gather. Lubes the clutch plates and circulates through the filter.
