Allis B
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Topic: Allis B
    Posted: 30 Aug 2026 at 3:54pm
The shifter side plate is leaking oil and needs a new gasket. Does the shifter need to be removed to take the plate off?
'41 Allis B
'49 Farmall Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2026 at 4:12pm
the round plate has the shift forks and rods mounted to it.. when you pull it out, the forks will disengage the gears.... replace the gasket and watch what your doing when you reinstall... shift lever does not need to be removed... but it pilots into grooves in the shift rail when you reinstall..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2026 at 4:15pm
looks something like this....
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2026 at 7:47pm
Can’t seem to find a gasket. Guess I’ll have to make my own. Any one know how thick it is? Does it matter how thick?
'41 Allis B
'49 Farmall Cub
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2026 at 5:17am
AGCO Part # is 70206561 They Show It In Stock
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2026 at 9:09am
ii think i cut one out of brown construction paper and put permatex on both side...010 inch is plenty..
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2026 at 12:47pm
Thanks
'41 Allis B
'49 Farmall Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 59 minutes ago at 9:46am
Finally replaced the gasket on the shifter plate. I had to make the the gasket. It was easier than I expected. The bottom half of the gasket was gone, no trace of it.
'41 Allis B
'49 Farmall Cub
