Allis C Rear Tires
rma1998 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rma1998 Quote  Post ReplyReply Direct Link To This Post Topic: Allis C Rear Tires
    Posted: 10 Aug 2026 at 7:23am
Can someone tell me if these tires will work on a C. The tires on the tractor has: 12.4-24 on 11" Rim 11-24.
Are they the same size?
Jim.ME View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2026 at 7:35am
12.4 - 24 is 12.4 - 24.  12.4- 24 is the current size designation for the tire that should be on an 11" wide rim, they just often do not show the wording for 11" rims any more.  The ones you are looking at are the same size, just a heavier ply rating.
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2026 at 12:31pm
yep... most of the tires were 4 ply.. the ones your looking at are 8 ply.. Heavier duty, maybe a little stiffer sidewall... should work great.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rma1998 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2026 at 1:41pm
Do you have to use tubes? I assume we'll need tubes. If so which ones?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2026 at 4:30pm
I get good radial tubes from a tire shop.  The shop can give you the right ones.  I suspect they will say for 11.2 and 12.4 tires.  Radial tubes these days are much better quality in most csaes.
