Diesel additives |
| Author | ||
Rusty Allis
Bronze Level Access
Joined: 16 Jul 2020 Location: Rhode Island Points: 181 |
Topic: Diesel additivesPosted: 31 Oct 2026 at 10:50am |
Group! Looking for some advice on diesel fuel additives
I have some older (80's-90's) equipment (tractors, skid steers etc) that get mostly put up for winter in an unheated building.
Last year we had one that when getting it ready in spring started/stalled wouldn't restart and when it finally did, wouldn't rev. After some heat and gentle taps on the IP it came around and has been fine all season. This has never happened in the past 15 years. It was a cold, miserable long winter here in the Northeast We've run some ATF every few fill ups, but is there a good product anyone can suggest to "pickle" these old girls for the winter? Just trying to avoid another spring fiasco because of course, it's always "I needed it yesterday" when it comes time to recommission the stuff for the season Thanks! |
| Sponsored Links | ||
TedN
Joined: 30 Apr 2025 Location: Central WA Points: 403 |
Posted: 31 Oct 2026 at 12:20pm |
I use Power Service, and usually have at least one tractor that I run through the cold weather. I have got to the point that I decided it is easier to just treat the fuel as we get it delivered instead of worrying about remembering to get everything treated in the fall. If you don't run the equipment when it is cold you shouldn't have to worry about getting it treated properly, but you need to read the label if you plan on using the equipment. There are different levels of treatment for different temperatures, and it is recommended to double the treatment if there is any percentage of biofuel. Depending on how much fuel you go through you may also want to add an anti algae product. Water is used in the refining process for diesel now, so you always have a chance of having some moisture in your fuel, part of the reason I have started using fuel treatment year round.
Ted |
190XTD seriesIII, 190XTD seriesI, maroon belly 7000, 7030, 7045, D14, 190XTD series??? project(or maybe parts)
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12524 |
Posted: 31 Oct 2026 at 1:09pm |
Power Service for me also. Works fine, usually 2 tractors run through the winter. Often have some cold harvest and fall tillage weather too. Try and make sure everything gets at least a half tank of treated fuel before the season starts.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5328 |
Posted: 31 Oct 2026 at 3:43pm |
There are several good additives. The injection pump shop that used to do our pump work when we were tractor pulling told me if you start with one brand, you should stay with that brand. They recommended not changing from one additive to another.
DanWi
Posted: 31 Oct 2026 at 4:35pm |
I wouldn't purposely switch back and forth to mix them but fuel may already have additives from the pump so how do you know what you are mixing. Just run the tank really low before a fill up and switch of products
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5491 |
Posted: 31 Oct 2026 at 5:21pm |
I also use PowerService exclusively. Over 40 years ago I had my tractor trailer almost die out one day. It would idle but couldn't rev at all. Another trucker stopped with a bottle of PowerService and told me to spin off the filter and dump all I could out. We filled the filter and put the rest in the tank. It fired right up and after about 10 minutes at high idle I had full power to get back on the road. I've used nothing but ever since. I had previously treated the trucks fuel with another brand treatment the day before when I got fuel, but that treatment wasn't up to the cold.
NEVER green
Posted: 31 Oct 2026 at 6:20pm |
Anti algae is a must, since they removed sulphur, it prevented algae, fuel only has a 6 month shelf life. Had a AMBACK pump with a new 2500.00 head get recked after 4 hrs of use, drained the tank and black tar barely ran out, what a mess to clean. An expensive mess. Wait till you read the warnings on the anti algae, but we had to remove the sulphur dont ya know.
Tbone95
Posted: 13 hours 53 minutes ago at 4:44am |
Also keep a bottle of Power Service 911 on hand. We had a year where it got very cold early and stayed that way. I got stranded feeding cows. It’s a miserable job in the cold but worked as advertised. |
Oldwrench
Joined: 12 Jan 2020 Location: Northeast Points: 176 |
Posted: 11 hours 12 minutes ago at 7:25am |
It seems there are three different potential problems - lubricity, anti-gelling and anti-algae. My understanding is that modern low sulfur fuel generally lacks the lubricity of old fuel, so a basic fuel additive like Power Service is needed all year round for older injection systems. In the cold, the winter additive with anti-gel accomplishes both. Is this correct? Should we be running a lubricity additive all time, for older equipment? Or is it just expensive hype, and the injection system is fine without anything, even the older ones?
dp7000
Bronze Level Access
Joined: 26 Sep 2021 Location: Winchester Kent Points: 194 |
Posted: 9 hours 7 minutes ago at 9:30am |
Oldwrench, that is a great question and I to would like our experts to weigh in. I use Power Service only in the winter.
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1166 |
Posted: 8 hours 44 minutes ago at 9:53am |
I question power service for anti gel….its made i weatherford tx. What do they really know about cold?
Tbone95
Posted: 7 hours 53 minutes ago at 10:44am |
I don’t know, but I follow their directions for temperature you expect and it works. We had a week of feeding cows in the-20’s last year and I never gelled.
Jim.ME
Posted: 7 hours 13 minutes ago at 11:24am |
Labs can put things in freezers, refrigerators, heat and do the testing. I will venture to say very few things are tested in place to begin with. Power Service works as does Howes (and many other products).
PaulB
Posted: 1 hour 12 minutes ago at 5:25pm |
Edited by PaulB - 1 hour 3 minutes ago at 5:34pm |
PaulB
Posted: 1 hour 7 minutes ago at 5:30pm |
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8605 |
Posted: 38 minutes ago at 5:59pm |
For my 1991 F-350, with the IH 7.3L IDI(indirect diesel injection), it use a small bottle of 2-cycle oil every fill. I figure if a small bottle can lubricate a 2 cycle gasoline engine, a small bottle should add lubricity to ulsd. |
