D15 diesel - getting fuel to the filters |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7732 |
Topic: D15 diesel - getting fuel to the filtersPosted: 11 hours 18 minutes ago at 7:19am |
I have my series 2 diesel looking more stock than when I got it. However, I am not able to get fuel from the tank up into the filters. I have 1/4 tank of fuel and I have had new seals put in the hand primer, but I cannot get it to pull fuel up to the filters. The primer was tested separately and it does work. I do have a very small leak on the 90 coming out of the sediment bowl if that makes a difference. Would filling the tank full make a difference? ![]() |
Joined: 11 Sep 2009 Location: illinois Points: 93505 |
Posted: 11 hours 13 minutes ago at 7:24am |
it should work at 1/4 tank, but if you look at that level compared to the filtes, the fuel level is only partialy up inside the filters.. a good test would be to fill the tank and test again... and YES.. any minor fuel leak can be a MAJOR air leak and cause loss of suction.
--------------------- this is WATER instead of FUEL... but gives you a good idea of a "MINOR LEAK"... How This Affects Flow Through a Crack
Edited by steve(ill) - 11 hours 8 minutes ago at 7:29am |
Nathan (SD)
Joined: 11 Sep 2009 Location: Day County SD Points: 1328 |
Posted: 8 hours 36 minutes ago at 10:01am |
If the tank was full, you could gravity bleed it and throw the primer away. Thats just me.
Jim.ME
Posted: 7 hours 17 minutes ago at 11:20am |
Fix the leak for starters. Adding more fuel to the tank will give it more head pressure and it will leak more. A leak on the suction side of any pump is not a good thing.
Posted: 3 hours 33 minutes ago at 3:04pm |
is that a factory setup with the primer pump stick out the top of the filter , way up in the air ?.... would have been a better design to have an elbow on top of the filter and put the primer at the side of the filter, or below.......... but fixing the LEAKING ELBOW might fix all your problem.
DSeries4
Posted: 3 hours 8 minutes ago at 3:29pm |
That's how a series is 2 is supposed to be set up - wasn't like that when I bought the tractor.
Some have said it is not the greatest set up with the primer that high up, but given the space constraints around the sediment bowl, that's where it sits. I will top off the tank and fix the leak and it should be good. Thanks for the responses. |
