Allis Sae 20W20 barel of oil.
twinson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinson Quote  Post ReplyReply Direct Link To This Post Topic: Allis Sae 20W20 barel of oil.
    Posted: 04 Oct 2026 at 10:24pm
I have a sealed 55gallon barrel of Sae 20W20 oil from Allis.  I no longer need this.  Any interest.  Thank you.  Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 04 Oct 2026 at 11:15pm
Hydraulic oil ?????
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinson Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 39 minutes ago at 7:48am
Barrel is labeled SAE so I was thinking Motor Oil.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 34 minutes ago at 9:53am
Probably a gasoline engine type of oil, I'd imagine.
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 7 minutes ago at 10:20am
Hydraulic oil is labeled SAE too
My mistake, hydraulic oil is aw or iso
Edited by john2189 - 16 hours 2 minutes ago at 10:25am
'41 Allis B
'49 Farmall Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote twinson Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 6 minutes ago at 12:21pm
I was thinking WD-45, D17, D19 as we used to have those tractors for light duty use.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 33 minutes ago at 12:54pm
SAE is Society of AUTOMOTIVE ENGINEERS... which means the oil must be ENGINE COMPATABLE... 20W20... basiclly means its a straight 20wt engine oil.... You can use 2owt engine oil as HYDRAULIC oil in most of the older tractors... maybe pre 1960..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 28 minutes ago at 12:59pm
newer HYDRAULIC OILS are labeled "AW"  .. which means it has ANTI WEAR addatives in it specifically for  valves, pistons and pumps... normally with anti FOAM additives also..
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 44 minutes ago at 6:43pm
Well, if it says ALLIS-CHALMERS on the barrel, it should be pre-1985 for age, which would make it 40 years old minimum. From about 1970 onward, the hydraulic oil was "Power Fluid 821", which was used in transmissions and hydraulic systems. In a D-19 owners manual, the hydraulic oil requirement was SAE 20-20W non-detergent of "ML" service classification. It's hard for me to believe there isn't anything else printed on the barrel to help figure out what type it is.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 7 minutes ago at 7:20pm
My late Father-in-law ran Pennzoil 20W20 motor oil in his vehicles and the WD Allis year 'round. I haven't seen it for sale in many years now.
