Allis B
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Topic: Allis B
    Posted: 2 hours 58 minutes ago at 6:06am
Just curious, Is there any way to tell if a 1942 engine is factory original? I’m about ready to rebuild it soon.
'41 Allis B
'49 Farmall Cub
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 31 minutes ago at 7:33am
the only things that can possibly not be "original" is the piston / liners / rings... You never know if they have the overbore pistons and liners, or factory parts... Gaskets, cam, crank, rods, gaskets, everything else will be "original" ... at least in size... You would have to take the head off to see what the bore is... There were some aftermarket  pistons that might use a different size rings... so pull one piston before you order rings..
