8050 muffler eliminator
Dkienzle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dkienzle Quote  Post ReplyReply Direct Link To This Post Topic: 8050 muffler eliminator
    Posted: 19 Sep 2026 at 9:25pm
Is there anywhere that you can still find a muffler eliminater for a 8050? I think the company that used to make them closed, any other leads? Thanks
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:07am
 Had one threw it in the scrap, had outrageous 180 degree angle on it.
  Are you looking for more flow?
Edited by NEVER green - 7 hours 21 minutes ago at 8:06am
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 10:43am
was Thomure Mfg. Think some one took over some of their stuff but not sure. Mine has a section sliced welded 180 which is a little sharp and crude but ok. I never seen much difference on the pyrometer. Not enough noise difference in cab to notice. Have 2 8070's. One with and one without. The muffler one is quieter outside of cab but that's it.
Ricky38 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ricky38 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 11:56am
Jim Kemp on the Wheel Horse forum is your guy. He builds custom stacks and eliminators. Or just have a local exhaust shop bend you a straight pipe.
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 2:53pm
I emailed Thomure this winter.  he is still doing stuff just not as much as he was.  I think he makes them to order or when he gets a couple to do.  I would call and see.  Thomure MFG
ryan
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 23 hours 18 minutes ago at 4:09pm
Thomure Part # Is AC759ASP I Googled It Cam Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 39 minutes ago at 9:48pm
I don't think you can bend a straight pipe that tight.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 35 minutes ago at 9:52pm
Lift parts warehouse shiws to have them
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Shows
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 6 hours 59 minutes ago at 8:28am
  A little crude...  it is terrible,   a plumber would point and laugh at that.  It aint no sweep elbow,  the curve is not even round.
  The muffler necks down from  4 inches to 2 inches in order to scavenge dust, also restrictive.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 60 minutes ago at 11:27am
Mine doesn't neck down. Has a horizontal asperator welded in outlet pipe. Have you looked at OEM muffler? Blows into rear chamber and has to find the outlet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 29 minutes ago at 11:58am
  Yes, I gutted one and it has more room to turn then that "thing", not great either but, air like water does not like sharp edges and short corners, that "thing "  has both.
