8010 low pressure hydraulic line |
PawPaw
Joined: 21 Feb 2024 Location: NE Indiana Points: 28 |
Topic: 8010 low pressure hydraulic linePosted: 31 Aug 2026 at 11:32am |
Where is the best place to plumb into for return line on sprayer with hydraulic pump?
Posted: 31 Aug 2026 at 11:55am |
A "case-drain" line ??? There are two hoses on a sprayer pump (in and out) and this is the third line/hose??
PawPaw
Posted: 31 Aug 2026 at 12:08pm |
Only 2 lines to hydraulic motor pressure and return. Sorry for not being clear. Sprayer manual says best to not hook return line to remote coupler.
Posted: 31 Aug 2026 at 12:37pm |
#1. Remove lower sight glass and adapt an O-ring fitting into that hole and check your oil level using the top sight glass. #2. Plug in your second hose to the other remote valve and place that valve in FLOAT and wire it into float so it can't be bumped into HOLD. #3. Remove the steel plate under the PTO gears and above the drawbar and drill/tap a connection into that plate with a coupler to plug your hose into.
PawPaw
Posted: 31 Aug 2026 at 1:01pm |
Thank you
