Zenith over flow |
3rd generation
Topic: Zenith over flowPosted: 8 hours 36 minutes ago at 1:39pm |
Allis C. I’ve tried it all. Carb has been cleaned with Berryman cleaner. The body also soaked in evaporust. Added inline fuel filter. Float height is good and floats do not hang up on side wall. New gasket under float needle seat body. I even removed the wire clip between the float and float needle. Tried different needles.
Only thing left is buy several needles and seats in hopes I get a good match. I’ve read the aftermarket carbs have poor performance. Is a Marvel carb an option? |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4044 |
Posted: 7 hours 51 minutes ago at 2:24pm |
does the float leak? boil it to see if it bubbles or hisses
3rd generation
Posted: 7 hours 41 minutes ago at 2:34pm |
No I checked that also. If I blow into an empty carb bowl it holds holding upside down. As soon as it overflows I disconnect fuel line from carb and attach a hose and blow it appears to hold but under gravity feed it overflows as soon as the bowl fills up with fuel valve open. I measured the original needle to be a few thousands larger than the new needle thinking it gets kicked to side of dead center into seat hole. Sad because this tractor has been completely taken apart and overhauled from lower drive to engine.
Les Kerf
Posted: 6 hours 34 minutes ago at 3:41pm |
Methinks the float doesn't float enough
Joined: 11 Sep 2009 Location: illinois Points: 89917 |
Posted: 5 hours 44 minutes ago at 4:31pm |
if you have tried several needles and they all leak, then i would lower the float like Les said..
Skip, W.Pa
Posted: 2 hours 16 minutes ago at 7:59pm |
I have had problems with the main jet discharge tube gasket leaking. Some were not tight enough and leaked at the round gasket under shoulder. Some the gasket dried out from sitting extended period with no fuel in carburetor. Makes you think it is a needle seat / float issue. When it leaks gas will wick it's way up past gasket and drip out the bottom of carburetor when tractor sits for period of time. Something to look at when you take carb apart.
HudCo
Posted: 45 minutes ago at 9:30pm |
what skip said set just the bowl level with the nozzle in and carfully and slowly fill it with gas and see if their is leaks bottom of those bowls can crack if they have had water in it and froze , but the nozzleis probley leaking at that gasket, 0if the float is good and the seat is polished
