will a wd45
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: will a wd45
    Posted: 19 May 2012 at 7:12am
handle an IH 6 row planter?
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 7:22am
How fast are you planning to pull it, which type of IH planter are you talking about?
It probably will do fine, but hydro, and or electrics may be an issue.
Still in use:
D17JIM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 11:35am
I pulled a 6 row IH with Fert tanks with a 44 MH for 5 years over 500 ac/yr.  A wd45 with some weights will do anything a 44 MH will and more I've had both.  It was a older plate planter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 9:33pm
2nd or 3rd gear. its a 60's or 70's plate planter. only hydraulics is up or down, which I have, just no down pressure. Un weighted, unloaded tires. sandy clay
German Shepherd dad
#WD234847
#WD88193
Dale H. ECIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale H. ECIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 9:49pm
My Dad planted for years with a WD45 and a 694 (6-30" rows) JD planter with dry fertilizer and did just fine. I think he planted in 3rd gear. I still have his WD45 but the planter went to China years ago.
Allis Chalmers Museum, Paris, Il.http:// www.allischalmersmuseum.com 217-275-3428
Lars(wisc) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wisc) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2012 at 9:49pm
corn planters dont 'pull' very hard, its the ability of the tractor to lift the unit that is usually the issue. if your ground is level what have will work. if you have decent hills you may have better results will loaded tires
KC-WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC-WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2012 at 9:18am
 I pull a 6 row IH 400 air planter, with my 45, in third gear no problem at all, and that is while running the 540 hydro pump as well. These little tractors can do a lot that people don't think they will.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KC-WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2012 at 9:33am
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2012 at 7:47pm
I'm guessing it would be an IH  model 56 planter you are trying to pull?  My 45 has loaded rears and it pulled a 4R30 IH 56 planter like it wasn't even back there.  Unless you have some gnarly hills I say you'll do fine.
The one small issue your going to have is raising it.  The ol' 45 takes a few seconds to get it in the air.  You have to raise it enough to trip the marker mechanism and disengage the row units/fertilizer drive.  You can just snap the hand clutch to stop it and raise it that way.  If you try to do it while driving it will drop seed and fertilizer all over the place when you turn around on the headlands.
Does your planter look like this guy, by any chance?  If so its a IH 56.
Edited by Roddo - 21 May 2012 at 7:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2012 at 10:19pm
I really like the photos!!! Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2012 at 6:17am
58.
German Shepherd dad
#WD234847
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2012 at 9:15am
Basically the same.  You'll do fine!
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2012 at 9:25pm
i planted with a allis 600 4 row 30'' with liquid  and a d17 with no weights but it had duals the problems i had was told above was it took to long to raise  and 60 gal of gas for 60 acres of corn.
190XT,D17and 7045
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2012 at 9:52pm
If you can find an Allis hydraulic cylinder it will raise and lower just fine. I have the one Dad used on our planters, plows and other pull type equipment, it raises quickly enough.
I just replanted 15 acres of corn with my series I D17 and a 4 row 30 notill planter. I didn't use 5 gallons of gas and I had some road time between fields.
I know with fertillizer your planter pulls a little harder than mine, there is no way you should have used a gallon of fuel per acre unless something was wrong or you were going uphill each way. LOL
I don't think my 17 will use a gallon per acre pulling 3 - 16's.
It does raise a little slow because the planter uses two "modern" lift cylinders. one on each wheel.
Edited by Dave in il - 22 May 2012 at 10:28pm
AGCO My Allis Gleaner Company
