What makes a WD pop when throttle is closed? |
| Author | ||
kevin LA-CA
Joined: 12 Sep 2009 Location: california Points: 86 |
Topic: What makes a WD pop when throttle is closed?Posted: 14 Mar 2026 at 8:39pm |
I know that the WDs always pop when you close the throttle quickly. Mine really pops. Loud - 2 or 3 bangs.
Magneto ignition. I have timed by ear - don't have a timing light. Also aftermarket marvel carb with adjustable main jet. If I got found a light, where is the timing mark? |
| Sponsored Links | ||
Joined: 11 Sep 2009 Location: illinois Points: 90572 |
Posted: 14 Mar 2026 at 9:01pm |
you dont need a light.. You can static time it at TDC on #1 cylinder.... When started, the MAG impulse will change that to the FIRE mark..
i think your timing mark is the set screw on the front pulley, pointed straight down... but others will confirm.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8966 |
Posted: 14 Mar 2026 at 10:45pm |
Mostly the idle jet setting I think. POP BOOM POP! Yep they are great!
sparky
Joined: 13 May 2011 Location: So. Indiana Points: 1831 |
Posted: 15 Mar 2026 at 1:20pm |
To me sounds like it’s tuned correctly.
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1589 |
Posted: 15 Mar 2026 at 6:44pm |
My WD45 does the same. Means it is running properly but I have no idea why! I think maybe because the exhaust is so short and straight thru. No back pressure. Automotive engine with just headers on it has same tendency.
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4063 |
Posted: 15 Mar 2026 at 7:41pm |
remember when cars had carburators ? what they sounded like when they was going down the hiway and they let all the way of the gas
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3190 |
Posted: 16 Mar 2026 at 12:18am |
And turning the key off going down a hill with a big truck and then turning it back on.Big bang
rw
Joined: 28 Oct 2009 Location: United States Points: 388 |
Posted: 16 Mar 2026 at 5:35am |
It is a lot of things changing all at once. Throttle closing quickly lowers volume and temp and the raises the percentage of unburned fuel in exhaust flow through muffler. Fresh air with oxygen gets drawn in and causes the pop (explosion and flame). If you slowly close the throttle you control the rate of these changes and it stops the sudden rush of cool air full of oxygen so no sudden explosion. My WD has some exhaust leaks at the manifold. At level throttle mid RPMs with not much load it puts out a lot of blue flares with not much pop only visible after sundown.
Les Kerf
Posted: 16 Mar 2026 at 12:30pm |
Yup. Followed by a continuous loud roar from the split muffler!
DanielW
Posted: 16 Mar 2026 at 12:46pm |
Although I'm not an expert and I agree with all others about them (and a lot of other old carbureted equipment with primitive ignition advance) often popping, it doesn't hurt to check the exhaust valve lash and (most significantly) the seals around the throttle & choke plate shafts going into the carb. Those are two aspects that can cause a heck of a lot of popping when idling down or when the engine is being pushed/over-sped by a heavy load.
At our Northern farm, one of the hills between on the road between our hayfields and the farm is very steep (almost dangerously steep). Back in the day when we did more square bales and were running the roads several times with a heavy load of square behind and old tractor, they'd often popping as you idled down towards that hill, and even more so as the load was pushing against the engine going down that hill. You never noticed it much in normal operation. If you kept the carbs shaft seals tight and exhaust valves set with a couple thou extra clearance, it would significantly reduce the amount of popping. The Massey 44 and Super W6 were always the worst offenders. Eventually the W6 got a valve job and it pretty much elminated popping.
Robert Musgrave
Silver Level Access
Joined: 11 Sep 2009 Location: SE Wisconsin Points: 246 |
Posted: 17 Mar 2026 at 6:36pm |
"2 'cracks'--after WD throttle wide open--slam back to Idle--engine should make 2 'cracks' (backfire?) before coming to rest at idle. Told to me by Jim Smith, salesman at Smith Implement Co., Arlington, Ohio, as told to him by Eldon Bash, old mechanic at said dealership in 2009.
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12408 |
Posted: 17 Mar 2026 at 7:09pm |
Robert Musgrave
Silver Level Access
Posted: 17 Mar 2026 at 7:29pm |
The dealership was on the East side of Main Street (US Route 68) just north of Corbin Bros. Chevrolet garage. Just about 10 miles south of Findlay.
Tbone95
Posted: 18 Mar 2026 at 6:53am |
Tbone95
Posted: 18 Mar 2026 at 7:00am |
US 68 to Kenton, then OH 31 to Marysville, then to Columbus etc. I always thought that was some beautiful farm country!
Brian G. NY
Thanks(1)
Posted: 5 hours 16 minutes ago at 4:38pm |
HudCo, yes I remember those days well! Open the valve when going down a long hill and those glasspacks "rapped" really nice. Oh, the things kids will do for fun!! Another of my favorite exhaust sounds is a WD-45 wide open under a good load! They also "rap" real nice going down hill with a good load behind them. I was always a Ford guy but the sound of a 6 cyl Chevy with a Fenton split header and a set of "Smitty's" is one of the fondest memories of my early driving years. Wow.....I think I kinda got off the beaten path just a little. Sorry, us old pharts sometimes just have to get "lost in the fifties" once in a while.
Edited by Brian G. NY - 5 hours 14 minutes ago at 4:40pm |
