What makes a WD pop when throttle is closed?
kevin LA-CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kevin LA-CA Quote  Post ReplyReply Direct Link To This Post Topic: What makes a WD pop when throttle is closed?
    Posted: 14 Mar 2026 at 8:39pm
I know that the WDs always pop when you close the throttle quickly. Mine really pops. Loud - 2 or 3 bangs.
Magneto ignition. I have timed by ear - don't have a timing light. Also aftermarket marvel carb with adjustable main jet.
If I got found a light, where is the timing mark?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2026 at 9:01pm
you dont need a light.. You can static time it at TDC on #1 cylinder.... When started, the MAG impulse will change that to the FIRE mark..
i think your timing mark is the set screw on the front pulley, pointed straight down... but others will confirm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2026 at 10:45pm
Mostly the idle jet setting I think. POP BOOM POP! Yep they are great!
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 1:20pm
To me sounds like it’s tuned correctly.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 19 hours 17 minutes ago at 6:44pm
My WD45 does the same. Means it is running properly but I have no idea why! I think maybe because the exhaust is so short and straight thru. No back pressure. Automotive engine with just headers on it has same tendency.
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 20 minutes ago at 7:41pm
remember when cars had carburators ?     what they sounded like when they was going down the hiway and they let all the way of the gas
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 43 minutes ago at 12:18am
And turning the key off going down a hill with a big truck and then turning it back on.Big bang
rw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rw Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 26 minutes ago at 5:35am
It is a lot of things changing all at once. Throttle closing quickly lowers volume and temp and the raises the percentage of unburned fuel in exhaust flow through muffler. Fresh air with oxygen gets drawn in and causes the pop (explosion and flame). If you slowly close the throttle you control the rate of these changes and it stops the sudden rush of cool air full of oxygen so no sudden explosion. My WD has some exhaust leaks at the manifold. At level throttle mid RPMs with not much load it puts out a lot of blue flares with not much pop only visible after sundown.
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 31 minutes ago at 12:30pm
Yup.
Followed by a continuous loud roar from the split muffler!
DanielW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 15 minutes ago at 12:46pm
Although I'm not an expert and I agree with all others about them (and a lot of other old carbureted equipment with primitive ignition advance) often popping, it doesn't hurt to check the exhaust valve lash and (most significantly) the seals around the throttle & choke plate shafts going into the carb. Those are two aspects that can cause a heck of a lot of popping when idling down or when the engine is being pushed/over-sped by a heavy load.
At our Northern farm, one of the hills between on the road between our hayfields and the farm is very steep (almost dangerously steep). Back in the day when we did more square bales and were running the roads several times with a heavy load of square behind and old tractor, they'd often popping as you idled down towards that hill, and even more so as the load was pushing against the engine going down that hill. You never noticed it much in normal operation. If you kept the carbs shaft seals tight and exhaust valves set with a couple thou extra clearance, it would significantly reduce the amount of popping. The Massey 44 and Super W6 were always the worst offenders. Eventually the W6 got a valve job and it pretty much elminated popping.
