Well it is painted Orange....
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: Well it is painted Orange....
    Posted: 16 Apr 2012 at 11:11am
Picked up this nice 3pt  Graham Hoeme chisel plow at the auction last week. With 15" sweeps it makes the 175D work....and glad I put it on the tractor with the loaded 18.4's!
Anyone know if they make 4 rib tires like the one on the right in the 9.5L-15 size?  I'd like to get a mate for this one.
ALLIS EXPRESS!
This year:
David G. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David G. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 11:27am
I have a Graham Hoeme pull type chisel plow 7 shank. Nothing to regulate depth besides the hyd cyl. I pulled it with my 4020 JD as deep as she would go. I definitely knew it was back there. As for the tire, my dad put a set of 4 rib tires on a tractor 3 or 4 years ago. They were the same size. I would guess they are still available.
Edited by David G. - 16 Apr 2012 at 12:52pm
Mike56073 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 12:14pm
  Have you checked Miller Tire?
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 12:49pm
Everything I found is 3 rib in that size, what brand is it?
Charlie
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 2:49pm
Eldon, you pulling that plow in broken or fallow ground?
1944 Allis C
1960 Allis D-17 LP
Redwood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 3:17pm
A quick search on the web shows nebraska tire has that size in a four rib  not sure what brand but if you check it out and find who makes it... you might find a closer supplier.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 3:45pm
We painted all the attaching parts for the shanks (springs, brackets,washers, bolts,etc) on ours bright orange... That way when a shank hooked a rock or root, and let go, we could find all the parts when they came back to earth... It made putting it back together a lot easier!
They are a nice unit.
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 4:39pm
I had some fall plowed ground that the quack grass was coming up in....it pulled pretty hard when I hit the grassy areas, especially when it started to plug up!
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 4:41pm
Yeah I did a little search and found a Titan for $171 and a BKT for $147...plus freight. Will have to check the local guys....I guess there was a reason they put the cheapo multirib on the other side......
ALLIS EXPRESS!
This year:
