We bought the WD, questions ensue.
mamabear526 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mamabear526 Quote  Post ReplyReply Direct Link To This Post Topic: We bought the WD, questions ensue.
    Posted: 30 Aug 2016 at 1:36pm
We bought the WD and confirmed it is a 1950 WD. Now I am trying ti figure out where to get a manual. We found one but it is definitely not a service manual. HELP!!
Also I want to confirm what goes in the following spot. The dip stick was almost bare so we need to be sure here is a picture.
sjerden View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote sjerden Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2016 at 1:38pm
20w-20w oil. That's the hydraulic fill. Fill with rams extended.
WF owner View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2016 at 1:44pm
You can also use hydraulic fluid, but make sure it is the fluid you use in transmission and rear end. If you check the container, it should say the hydraulic fluid meets the specs for Allis Chalmers 821 Power Fluid.
Post Options Post Options   Thanks (1) Thanks(1)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2016 at 1:49pm
There are several companies that have manuals. There are three different manuals for your tractor; an owners manual, a parts manual and a service manual. For the price of them, it's a good idea to own all three.
Try to find Allis Chalmers manuals, as opposed to the I&T manuals. The I&T are good, but the AC manuals are much better.
Try some of the advertisers on this forum; Sandy Lake, DJ's. and Tony's tractors are a few that come to mind. There are several others, too
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2016 at 2:27pm
I use John Deere hytrans oil in my WD45 in that location. Any good hydraulic fluid should work there.
Start with getting an operator's manual. That will tell you everything you need to know about how to operate and maintain the tractor. It's always nice to support our site sponsors.
Here's an ebay link so you can see what a manual looks like. Be careful so you don't buy the CD-ROM computer version (unless you want that...)
Congrats on your first tractor! Hope you have lots of fun with it.
http://www.ebay.com/itm/ALLIS-CHALMERS-WD-TRACTOR-OPERATORS-PARTS-MANUAL-OWNERS-INSTRUCTIONS-/391181091347?hash=item5b1435c213:g:YeoAAOSwT6pVia8T
WDDave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WDDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2016 at 5:09pm
If you haven't already you might want to check the gear oil level in the trans and differential case.
   These are separate from the Hydraulics where your dipstick is located.
They are the two square head plugs one is to the right of the HYD dipstick ,the other is the next one back.
   These should be full to the opening when you take the plug out.
Also if the tractor has sat outside take notice what the color is if it looks milky you should drain and re-fill.
   There are different opinions on what to use I used 80w-90 gear oil in mine.
I also used this in the final drive's.
WD ,wide front, with loader
Post Options Post Options   Thanks (0) Thanks(0)   Quote mamabear526 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Sep 2016 at 10:11pm
You guys are awesome!! Thank you so much!
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2016 at 9:16am
I downloaded my manuals from somewhere...... Grampa's tractor maybe?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Sep 2016 at 2:32pm
Congratulations on the WD added tot he family! BTW that hydraulic dip stick will only have a little bit on the tip as marked when full.
Nice tractor you have there. I have 3 running WD's:) Lots of folks to help on here too.
