Wd brake help
plowboy8550 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plowboy8550 Quote  Post ReplyReply Direct Link To This Post Topic: Wd brake help
    Posted: 18 Jan 2012 at 5:52pm
I am trying to replace the brakes on my wd and im not having much luck.. The bottom pin is frozen. Ive tried sprays heat and welding a nut on and trying to twist it. I havent had any luck yet any ideas or tips?
Jeff B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff B Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 6:42pm
Cut it out with a torch, I have had to do this to most I have fixed brakes on.
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 6:48pm
         Jeff is right. Best way when they are stuck that bad is to cut them out.
                                            John Carlson
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 6:55pm
You can use a torch, but be careful of a couple things.   One, there is mouse nests galore in there, so you will most likely have a small fire so be prepared.   Also, when you are cutting the pin, cut it straight and not on an angle so that you don't accidentally cut the lower ears on the brakes.   I learned the hard way after ruining one set of mine.   cut out a piece, hammer the pin in till it hits the other part, repeat until the outer part of the pin is gone.   Usually the inner pin you can take a needle nose visegrips and clamp on and pull it in, as this one isn't the part that is seized.   Once done you can buy a new set of pins, of make your own.   A little antiseize on the new pins will help the next guy 50 years from now.   Good luck.
1955 WD45 diesel 203322 was my dad's tractor, 1966 D15 23530, 1961 HD3 Crawler 1918, 1966 D17 IV 83495, 1937 WC 41255, 1962 D19 6221
Post Options Post Options   Thanks (0) Thanks(0)   Quote plowboy8550 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 7:43pm
Thats what I was afraid of. I was hoping there was another way. I will give it a try, hard to say how long it has been since the pin has been out.   Thanks for all the help
paul s. mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paul s. mn Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 7:44pm
you will have to suffer likethe rest of us that had the same chore to do with brakes. the previous post are all good advice.be careful and good luck!!!!!!!!!!!
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2012 at 9:05pm
have replaced several sets of brakes,some come out with a good pair of vice grips,but most do not...thank the good lord for a  plasma cutter.....
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 8:33am
A safe but slower method is to drill out the center of the pin as much as you can then heat the hell out of it with a heating tip. Drilling it out to a thin wall reduces the amount of steel to heat. The drive in and cut method only works when it's loose. Mine was not even after all of the tricks had been applied.
'34 WC #629, '49 G, '49 B, '49 WD, '62 D-19, '38 All Crop 60 and still hunting!
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 8:39am
Chuck has it right.
"Burgie"
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2012 at 9:33am
The pin freezes up on the outside pin boss where it starts thru the diff housing.  If you can the the torch tip close where the pin boss and pin are and heat there you stand a fair chance of loosening it.  Its hard to get the torch head positioned where you want it cause there isnt much room and you cannt see it.   One time I had a pin frozen up on the brake band housings-that one had a lot of mouse nest in it.  Good luck
This page was generated in 0.039 seconds.
