Wanted: Split Rims for Model B |
GreenOrange ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Wisconsin Points: 836 |
![]() ![]() ![]() ![]() ![]() Posted: 23 Apr 2025 at 7:08am |
Looking for a nice set of split rims (split bead) for an early Model B tractor. Thank You!
https://www.allischalmers.com/forum/uploads/21138/20230823_194648_compress62.jpg Edited by GreenOrange - 23 Apr 2025 at 7:04pm |
Steve in MI ![]() Bronze Level ![]() ![]() Joined: 09 Jan 2019 Location: Hesperia Mi. Points: 28 |
guess I would have to see a picture can't say have ever seen split bead on block allis
spell check kicked in again B allis
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 85532 |
I have seen a couple at tractor shows... on pre 1940 tractors... always wondered if it was factory, or taken off semi truck.. they were 24 inch..
i have a bunch of B's 1939 and up but none have split rims
yep...i have "heard" there were a few built in 1938.
The earlier 1938 tractors had them. I put a link to a picture in the original post.
Edited by GreenOrange - 23 Apr 2025 at 7:05pm |
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4928 |
In my earlier days on the farm, we had a B with a 3 digit serial number that we were very sure was all original when we got it. It had lock ring type rims. One was nearly unusable as it had probably has CaCi in them since new.
Lon(MN) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Merrill Wi Points: 2000 |
I have some clamps but no rims.
http://lonsallischalmers.com
well Iearned something new, will have to watch at the shows and see if I can find one thanks
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 41820 |
Keep seeing 2 or 3 piece rims called SPLIT RIMS - They are not , what are called lock ring rim where a outer ring is held onto full width inner rim by a lock ring which is either a 1 or 2 piece fixture held in tire bead area .
SPLIT RIMS were 2 pieces and joined in center section of rim by fitting the 2 halves together by deforming one half over other and then locked together with groove area. Bead area of tire fit onto each half with lock at center to join rim to working fixture . Picture shown is a 2 piece rim with split lock ring - rim would have size at bead area the same for inside and outside area to fit tire inner bead diameter . A 3 piece would have slight step down at outer bead area |
"Challenges are what make life interesting; overcoming them is what makes life meaningful." |
https://youtu.be/PesIdB2wFjI?si=RwQvZRNgvMYB6TMg
Smaller rim but shows difference - |
SteveMaskey(MO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Wellsville, MO Points: 610 |
These are rusted out but here is what they look like
KMAG ![]() Orange Level Access ![]() Joined: 26 May 2020 Location: Elizabethtown, Points: 678 |
That is a lock ring wheel. They were used on Dodge/Ford pickups until about 1968 and US military vehicles and International trucks into the 1980s.
Very different than split rim -aka "widow makers" |
Agreed - they’re not split rims. I’ve heard them called split bead, split ring, and lock rings, and definitely understand the difference. I called them split rims in the title because that’s how they’ve been discussed on this forum and how they’re often referred to for the B. If they actually did use true split rims on this tractor, I personally wouldn’t even mess with them. This style I can work with, albeit carefully.
Edited by GreenOrange - 26 Apr 2025 at 6:13pm |
