vbelt running with a twist |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3997 |
Topic: vbelt running with a twistPosted: 20 Sep 2016 at 10:33pm |
what will run better on pulleys that run on a half twist- A section ,B section or 4l's, 5l's
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 20 Sep 2016 at 10:56pm |
hexagon belts
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8459 |
Posted: 20 Sep 2016 at 11:44pm |
X2
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54731 |
Posted: 21 Sep 2016 at 5:03am |
hexagon belts would be classified as AA, BB, CC etc...
Butch(OH)
Posted: 21 Sep 2016 at 5:30am |
I beg to differ with the Nebraska redneck but the hexagon belts are for arraignments that run on both sides of the belt and if run twisted they will flip easier than a standard belt due to less shoulder. Most factory twisted belts run in deep groove pulleys. HP required determines what belt you use, twist has nothing to with it. If you can use an A belt use the pulleys that are machined for both A and B belts and they will work great. Dodge and Woods both make them.
Edited by Butch(OH) - 21 Sep 2016 at 7:52am |
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5198 |
Posted: 21 Sep 2016 at 6:21am |
Belts that need to run twisted MUST be installed correctly as per the machines manufacturers instructions. Done any other way they will roll. AA, BB or CC belts are two belts made as one, side by side. If you are constantly having problems a round belt may be you only hope.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24901 |
Posted: 21 Sep 2016 at 7:45am |
If I'm 'picturing' this right , you have a 'mule' drive so a HIGH QUALITY 5L will run very well ! Get a 'kevlar' belt, one DESIGNED for 'tight' corners..regular V-belts only like 'straight' runs between pulleys.
proper belt is 3-4X cost but will last a very long time ! |
