two row planter question
creekfisher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote creekfisher Quote  Post ReplyReply Direct Link To This Post Topic: two row planter question
    Posted: 26 Feb 2011 at 11:09am
I have a two row ac planter (dont know what model - see photos).  Anyway, below the top plate that the seed box sits on there is the driven gear shaft that turns the seed plates within the box.  If you take the top plate off and look at the shaft there is a hole in the shaft that I assume houses a roller pin that keeps the gear side from protruding out.  Just need to confirm if this is the case, thanks.
bugbird View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bugbird Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2011 at 5:42pm
I'm not sure of the model.  We had 70, 72, and then 74 units.  The 74 had gauge wheel so I don't think that is it.  But, you are right about the roll pin.  I believe that the bevel gear goes on teeth inward and the roll pin held it on.  If I remember right you had to be careful that the roll pin was not too long.
Post Options Post Options   Thanks (0) Thanks(0)   Quote creekfisher Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2011 at 8:05am
Roll pin it is....  Fixed and ready to go, if this monsoon season ever ends!
This page was generated in 0.039 seconds.
