G with Tiller
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: G with Tiller
    Posted: 28 Oct 2013 at 8:17pm
Has anyone seen a G with this setup before.
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2013 at 9:36pm
no, I never saw a mufler like that.
Or did you mean the tillers. They are similar to Howard rotovators. May even be made by them or a later version of the ones that I have seen. Bob
Edited by Chalmersbob - 28 Oct 2013 at 10:03pm
4 B's, 1 C's,3 CA's, 2 G's WD, D14, D15, B-1, B10, B12, 712S,
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2013 at 9:42pm
Brian, is that at Tackaberry's place up around Athens?  I know the guy has tons of trucks and tractors of all colors.  I've never been there, but I heard about him from my neighbor.  As far as the tiller assembly, I do not believe that it is factory.  It would be interesting to see how it works though.
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2013 at 7:43am
That is a pretty neat set up --
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2013 at 5:31pm
Myron, yes that is the only other piece of orange at Tackaberrys.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2013 at 5:40pm
there's a "G" on BigIron sale that has tire protectors on it, never seen one like that either!
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2013 at 7:19pm
I thought the G had about 10HP. Would it have the nads to run that?
Just asking because I would like to have one. Be perfect for me with all the other gizmo's you can put on them.
Accountant (wife) would have a problem with it though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2013 at 9:02pm
Shameless, is this the one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2013 at 7:30pm
Can anyone tell us what the tire protectors are for.
nctractorman83 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nctractorman83 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2013 at 7:35pm
Both those G's have some interesting set ups I like.
ErikR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ErikR Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2013 at 7:38pm
I'm no farmer, but I'd bet they're for pushing leafy row crops out of the way so the tires don't run over things??? yes/no??
Edited by ErikR - 01 Dec 2013 at 7:39pm
1950 B
Auntwayne View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Auntwayne Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2013 at 7:53pm
     To protect the tires Brian , sorry you set yourself up on that one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2013 at 8:27pm
Ya Auntwayne, I thought that after I posted it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2013 at 8:49pm
The B had sheild similar to that available. They were for beans, so the plants didn't get run over. Bob
GaiaMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GaiaMan Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2017 at 6:41pm
Hello Everyone,
I just acquired a "new" G model with the same exact setup, i.e., the Ariens tillivator mounted on the belly.  We had to mount it without instructions so, it took a bit of time.  Everything went well.  However, we cannot get both belts, 1 from the engine pulley to the center pulley system and, 1 from the center pulley system to the tiller,  to reach the correct tightness.  The tightener with the turnbuckle(?) has been repaired/welded so I am not certain if it the correct length.  Its length will effect how the pullys' tighten.  There are other factors that will effect the belts, for example, where the tiller is mounted on the frame, actual belt lengths, Center pulley system mount location, etc.  I have no idea if the belts are the correct one's for that machine.  They seem about right but, they may be stretched way out.
This tractor needs to get to work on our farm.  So, I need it working correctly and this problem is taking up quite some time to try and rectify.  I can see that the system is going to be awesome for our needs once this last kink is worked out.
Thanks guys for your knowledge.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2017 at 8:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2017 at 8:37am
Hay Brian, guy just west of me has/had on for sale, hydralics and the tiller.Figured I'd be 6' under if I'd bought it....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2017 at 6:50pm
I've seen similar set-ups before, on modern tractors, they are row till units, and likely you could find dealer info, on the internet.  Lots of that type stuff, in south jersey, and delmarva peninsula where lots of row crop veggies are sold...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2017 at 9:38pm
Ther is one for sale in Belevidere NJ on Craigslist right now.
They were used in the onion fields around Florida New York. Orange County.
I bought a G up there but it didn;t have the rorovators on it, but there was one sitting next to it that had the units on it. I think that ine went to Massachuetts.
Mine was extended in width by and extra 12" to accomadate 4 rows of onions. They used 6" aluminum rods with a long bolt through it from the rim to the wheel. The front axle and steering rods were also extended. I has to make it narrow again to get it on my trailer. Bob
This page was generated in 0.219 seconds.
