Wheel Wedge bolts?
1abfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1abfarmer Quote  Post ReplyReply Direct Link To This Post Topic: Wheel Wedge bolts?
    Posted: 10 Aug 2012 at 4:13pm
I am looking for a set of bolts that push the wheel wedges out of the wheel in order to move the wheels in. I need this for the 220 I just got home a couple of weeks ago. Let me know if you have any or if you have the specs for making a set.
Thanks,
Shawn
etex@ana-lab.com
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 4:22pm
special bolts, odd thread pitch. best to just get from agco. to many people try to make something work, but they rarely do.
HARVESTMOONPULLER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HARVESTMOONPULLER Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 4:30pm
7/8' bolt with 12 pitch thread. Just did the 210 yesterday 220 is next week. Sorry im not at the shop for the lengths but they are considerably longer than a 190s. Will be making a set most likely next week.
Riggs/Ia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riggs/Ia Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2012 at 10:16pm
All you need to do is thread your bolt into the halfmoon peice on the axle and then take a piece of steel over the hole that goes into the casting. weld a nut onto the end of the rod to attach a impact. the thing is you dont want to pull the collar out but push the casting off of the collars toward the tractor. i did this to the d 21 that havent been off in 40 years with the helpof a rosebud and an air impact hammer. we had to heat them twice with a half hour wait in between heatings. had them off in about 45 minutes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2012 at 12:39pm
D21 is like a 190 with 3 bolts. 210/220 is like 7000/8000 series with the two halves, and 6 bolts. (4 on 7010,7020, 8010?) Best to tap the holes first, then use anti seize and lots of patience.
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2012 at 5:36am
I have a nice set of originals for sale. 785-353-2392
