JD AMT-626
Brad(KS/MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad(KS/MO) Quote  Post ReplyReply Direct Link To This Post Topic: JD AMT-626
    Posted: 29 Jun 2012 at 10:11pm
Hello all,
I have crossed the line and bought my first piece equipement from another brand.  I bought a JD AMT626 (predessor to the gator) to use around the farm, and it has some minor issues.  I have tried the JD forums but I am not impressed with the help, this forum is ten times better.  The knowledge on this forum is so great that I thought I would reach out here.
Anyway, the 626 brakes are non-existant, and I think they just need adjusted.  I found an adjustment screw, but I want to make sure I am doing things right as new calipers are $330 each new.  Does anyone know how to adjust the brakes on these?
Also it will jump out of gear every so often, and I was wondering if someone knew how the detents are constructed in the transmission, or how to fix it.  I just don't want to damage it any more than it already has been.  I can tear into it if I knew what I was going after.
If someone has access to a sevice/tech manual that would be fantastic.  I only need info on these two things now.
PS.  I don't plan on buying any non-allis equipement anytime soon.
Take Care,
Brad Bergman
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2012 at 10:27pm
Brad, shoot me your email, I have the tech manual in a PDF file I can send to you
Joe
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad(KS/MO) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 10:43pm
The AC forum pulled through again!!  I would like to thank Joe for the manuals.  I got the brakes working decent, and I know what I need to do to fix the tranny.  Definitely a lot better response then the JD forums as I still have not received any good advice from them yet.  Thanks again, Brad
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2012 at 6:25am
Just don't park it in the WC barn.  Dave.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2012 at 6:27am
Maybe someone needs to post on the JD forums where to go for help if they have a breakdown.
