HOT minneapolis moline
EClark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EClark Quote  Post ReplyReply Direct Link To This Post Topic: HOT minneapolis moline
    Posted: 29 Jun 2012 at 3:37pm
all right guys need some help with a M.M. U, got a U that keeps over heating and when it get to temp it runs right out the top of the radiator. I have changed thermo-stat,replaced bad head gasket,went through the water pump, and flow tested the radiator. what am i missing? heads? cylinders? what was a common problem with the U? and if anyone knows someone that works on these old girls and might know a phone # would be great!
Thanks Eric
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2012 at 4:00pm
 Slipping belt, retarded timing, lean mixture, collapsing lower hose,Thermostat  installed correctly ?  Radiator must be clean in and out to transfer heat.
 One final thing, every radiator has a certain sweet spot where sufficient coolant is at a certain level, if it is overfull, it will flow over, if you add more coolant it overflow again.
 Some rads have a baffle over the tubes so you can't see the coolant level in the rad, is yours that style?  an inch and a half of is about right.You do have a working temp gauge, right Or you observe an overflow and assume over heating?
Edited by Gary in da UP - 29 Jun 2012 at 4:17pm
Kenny L. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kenny L. Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2012 at 4:05pm
cracked head. Kenny L.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2012 at 6:05pm
Like gary said most tractors don't have an over flow tank. The top of the radiator is the expansion tank.
When you replaced the head gasket did you have the head mangnafluxed for cracks? This could also cause your troubles.
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote EClark Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2012 at 11:10pm
no I did not check heads when I found bad head gaskets I figured that was the problem. i know should have checked heads. and when this thing gets hot it unloads about  3-5 gallons real quick. gary in da up I checked all that. its like this thing hate's me. if it was mine it would be going down the road!
Eric
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2012 at 8:04am
Try a new radiator cap.
Dusty
You say when it gets up to temperature the coolant spews out. It should not spew out until it over heats. There for it sounds to me that the radiator cap spring is weak.
Edited by Dusty MI - 01 Jul 2012 at 3:29pm
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2012 at 1:46pm
With radiator filled, engine cold, start engine and look down in the radiator, look for bubbles.  You may get a few when it starts up... if it continues bubbling after about 8-10 seconds, or it bubbles more, and faster, then you have a situation where compression gases are being pushed into the cooling system.  This will both displace coolant from the cooling system AND prevent coolant from getting to pockets at the top of the head, and around the combustion chamber.
Frequently, if you have combustion gasses displacing coolant from the head, the moment you shut the engine down, coolant will flow back INTO the head, and immediately flash to steam, yielding a wonderful green geyser in your face.
Combustion gasses can displace coolant in a myriad of ways.  I'm not familiar with the internal setup of the MM, but I'd look not only at head, block, and sleeves.  Typically, if you have a crack somewhere, it will either leak coolant into the engine (pan, or a cylinder), or out the engine (either the block or head) or into the airflow path (like through the exhaust port into the exhaust path and out) or intake (into cylinder and out).  The airflow path leak will make your shop smell like anti-freeze... and sometimes, particularly with an intake leak, it'll leak enough into a cylinder to hydraulically 'lock' the engine.  If it's leaking into the pan, you'll notice your oil level RISING.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2012 at 1:53pm
I would look for an MM forum, because cooling system problems, while being very simple in theory, are oftentimes quickest uncovered through experience shared with other MM enthusiasts.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2012 at 3:25pm
  GIVE ME A CALL   WIL SEND YOU TO RIGFT FELLA WITH PHONE#  HE CAN HELP
    1-574-342-4545
Post Options Post Options   Thanks (0) Thanks(0)   Quote EClark Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2012 at 10:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote EClark Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2012 at 10:15pm
Norm I'll give you a call Monday, guess I should have asked you when I was at your place Friday. got the keys to Jim that he wanted
Post Options Post Options   Thanks (0) Thanks(0)   Quote EClark Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2012 at 10:19pm
thanks for the info Dave but there forum isn't as handy as this site!!!!
TomSEOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomSEOH Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 7:18am
Had a 160 that done something similar, ended up having a cracked ring. Most definitely has to be a cylinder issue.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 7:58am
Remove the rad and pressure wash it.  Had cooling issues with the 8030 replaced the thermostat and blew out the rad with no improvement took the radiator out and pressure washed and that made all the difference.  Didn't think the rad had much to speak of in it but the water that come out was very muddy.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 8:21am
A plugged-up radiator is a high possibility... especially if it was rescued with the rad cap or either hose rotted-off (wasps), or had a prior history of overheats (refilling in the field using a bucket from the stream)...
And cleaning it out with a garden hose and nozzle wouldn't be unreasonable, but I don't think I'd feel safe taking a pressure-washer to it, unless it was a really, really weak pressure washer.  The forces generated by the washer tip are well above the strength of the solder joints at the top of the tube and tank.  If one were to pull the radiator, I'd recommend just taking it to a rad shop for a visit to their boiling tank, and while at it, have them flow it, patch up any leaks.  Good thing about this approach, is that if there's a problem, they'll find it pronto... and that may be all that's necessary to solve your problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 8:25am
Eric- when you replaced the thermostat, did you TEST it first?  Reason why I say... I've found very few NEW units that didn't work, but it's certainly possible, and very perplexing when it happens.  I've had two new-in-box (one off the shelf, one old stock) that didn't open.  The off-the-shelf was totally dead.   The old-stock unit (probably 30 years old) refused to open at 160f (for a big Hercules) but as the water was boiling, I tapped on it with a table knife (I was in the kitchen)... and it popped open.
Now, I always test mine... put a pan of water on the stove, and a bowl of icewater alongside... and move it 'tween the two a few times just to be certain.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 8:53am
Ditto on the thermostat check before installation.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote EClark Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 10:06am
dave and gerald thanks for the input. I'm on the 2nd thermostat because I thought the same thing. and radiator is spotless all ready been to the radiator shop. see what i mean. thinking heads or cyl. moline U's don't have liners so that rules out o-rings, or replacing liners.oh well I've pushed it off to the side for now need to finish painting my D17 before 4th of july! got a tractor show to go to.
Thanks for all the input on the moline Eric
EricTn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricTn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 3:37pm
Could it be the thermostat got installed backwards? Possibly air trap somewhere, got any bled plugs anywhere? Maybe not!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 4:08pm
For less than $8 at a good hardware store you can buy an "instant read" dial thermometer that has about a 6" long probe. You can lower it into the upper radiator tank to check coolant temperature. You can stick it through a small into the coolant in a head to check temperature there. And you only need a minute or less for a reading. Don't guess at the temperature, measure it.
Gerald J.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 9:07pm
Minneapolis Molines were notorious for cracked heads with several models. I suspect that but go ahead and check for easy stuff first.
Wink
I am a Russian Bot
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 10:30pm
Eric is certainly having fits with the U. It belongs to my "other brother Darrell", and he was part-owner of the White Equipment store in Remington with John Coty, and two other partners. John has been a mechanic since high school and is in his mid-sixties now. John replaced the head gaskets on this tractor last fall, but it has never been right. John rarely has a call-back on any of his work, and presently is a mechanic at a Case/NH shop. This U is a tractor from "hell", and has had the radiator rodded out by a very good shop, Eric checked the flatness of everything, and there is no obvious cracks. Somewhere is an answer to the problem. If I remember right, Eric has even taken the water pump off to check if the impleller is still tight to the shaft. I've talked to both Darrell and Eric about point dwell(or gap) and timing, because in the late 60's- early 70's Chryslers had problems with timing being advanced by worn or too tight of a point gap, causing them to overheat. Hmmm!  But as he said, he is going to have to shelve it and get his own D-17 fiinished for the 4th 0f July. It's been painted since very early spring, but he needs to wire and decal it! It really is a beauty!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2012 at 11:18pm
Ignition timing is always affected by point gap and rubbing block wear. Its probably more critical on an 8 cylinder engine than a 4 because the flats on the cam are so short if the cam diameter isn't big on the 8 cylinder engine. That's why its SOP to set the point gap first, then set the timing. And to set the timing each time the point gap is set.
Gerald J.
This page was generated in 0.091 seconds.
