d 17 series 4
acdave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acdave63 Quote  Post ReplyReply Direct Link To This Post Topic: d 17 series 4
    Posted: 27 May 2012 at 6:57am
i am getting ready to  paint my d 17, has anyone used valspar paint, and how did it turn out for you. i also need a couple pieses of sheet metal for it, i need the grill screen the cone it fastens to the  2 little side covers under the fuel tank, a set of lights. and decals. who makes a good set of decals, not asking for much am i. thanks David
allisorange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisorange Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 7:10am
          Valspar worked well for me. The vendors on this site should have most of the stuff you need. Give them a call.
                              John Carlson
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 10:18am
I am a shade tree painter and have used the Valspar paint with good results using a HVLP sprayer. A neighbor who is a good painter told me to apply the 1st and 2nd coats without hardner and to apply a light "wash" coat (mostly thinner with a little paint...I get mine by emptying the paint from the container and adding a little thinner) after the last coat without hardner then allow the paint to dry for a day and apply the final coat with the hardner after it dries to the touch. Followed his advice  (and after a few tries to learn the ins and outs of the wash coat) have become a respectful painter.
You can obtain good decals from Jim D (OK Tractor) and Tony C (Tony's Tractor). Norm (Norm's Toys) can probably help you with the needed tin
BillinValpo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinValpo Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 10:20am
For side panels check with Norm Steinman in Bourbon, In.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acdave63 Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 11:20am
thanks guys
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 1:22pm
sent you a PM, have most of what you need on our web-site.   www.djstractorparts.com
David 734-320-3470
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2012 at 8:37pm
  we have your needs also      can pick up parts--us30 northern ind  1-574-342-4545
This page was generated in 0.049 seconds.
