D17 Tach
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: D17 Tach
    Posted: 17 May 2012 at 7:28am
My Tach is shot. While looking online I am a bit stumped.
I see the version for the GAS model, so I am good there.
I need a drive cable. is 56" right?
I also see a Drive Adapter, what is that for?
Also there is a cable adapter, what is that for?
Also I am still looking for Vinyl Decals for a Series II. I see Series I and III,IV stuff but not II
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 7:40am
This is the closest set I have found for decals but it does include items that don't apply to my model.
Charlie
Bryan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bryan Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 8:08am
Maple- Hunter decals in Indiana. Excellent quality.
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 1:26pm
Charlie -
I bought a new tach cable for my Series I, I think was 60" but I am not sure.  I know there is plenty of slack in it.  Also I don't have power steering so I don't know if that moves the dist or not.
There is an adapter piece that is more less just a round rod with a flange  and a tab on one end.  The tab fits into a slot in the end of the shaft that drives your distributor.  The other end has a hole drilled into it with a slot.  This piece is supported by the adapter that screws into the base of the dist housing on one end and has the speedo cable threads on the other.
Evidently the original cables had a cable end that was round with a tab sticking up, it would fit into the hole in the end of the adapter and the tab goes in the slot to drive the cable.  The cable I bought from my dealer had a regular automotive style square end on it.  There adaptors out there that will change from square to the tab, I think MSD has them on their website.  They are a bit large though so you would have to turn them down from 0.18 to 0.15" I think.  I bought a plastic adapter that fit will, but the first cold spell we had it cracked.  So I coated it with JB liquid steel and carefully fitting it back into the adapter, making sure none got into the square hole.  Let it sit 36 hours and it has been working fine.  Tach works but the hourmeter part quit functioning.  Dang.
cheers,
Creek
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 1:35pm
Have all your items in stock. www.djstractorparts.com
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 7:42pm
we have all items in stock  my not need all the items   1-800-254-3116
Doug Acord View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug Acord Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2012 at 7:51pm
If the tractor is a true series Two Then the only decals are the D-17 in a rectangle decals for traction booster and small decals like that. If your tractor is missing the allis chalmers on it then you are going to want the Metal plates. Many parts dealers on here should have them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2012 at 7:48pm
  we stock the cable and adapter  also the keyed end and no adapter is needed
   1-800-254-3116
