Plow ID help
Chad(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad(WI) Quote  Post ReplyReply Direct Link To This Post Topic: Plow ID help
    Posted: 06 May 2012 at 7:02am
Anyone know what model AC plow this ?
Anyone know what a ballpark price would be for it? Thanks for any input.
DWC17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DWC17 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 7:07am
The reset portion looks like my 80 series snap coupler plow. I can't help you on the price.
    Dan
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 10:14am
Looks like late spring trips, which were late 80 or 9000 in my book. The frame isn't at all like an 80 frame, those angled cross beams are NOT 80 family. Might be a 9000, with pull behind hitch. Hitches seemed to have been sold separately from the frame, just like bottoms.
I can't find my plow frames book this morning, but it can be downloaded from http://www.grandpastractor.com/phpBB3/index.php There are two of interest there, one on plow frames and one on plow bottoms.
Minimum value is the scrap metal value, maximum depends on the number of bidders and how badly one wants it and can pay for it. Pull behind plows don't add load to the tractor axle for better traction so require a heavier or weighted tractor for best performance compared to a three point or semi mounted plow.
Gerald J.
orange knight View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange knight Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 2:39pm
Its a 9000 series 4 bottom plow. I had a friend that had one at pioneer power. Looks just like the 4 bottom 9000 series that I just brought home. They usally run between about $350 to $450 depending on its condition. I would buy it from you if you would be interested in selling it.
Edited by orange knight - 06 May 2012 at 2:43pm
952-290-1063
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 5:08pm
The plow looks just like picture of in my 80 series wheel type  book has. I sold one like that to my nephew except mine is a later one with the bigger bar on top.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 6:51pm
in my plow frames book, the side plates of the spring trip are bent to make a flat flange the the truss tube bolts to. These spring trip side plates are flat like to 80 family spring trips. The spring support is for the later rather than the earlier plow frames.
I see the angled cross members of the wheel hitch, but not the angled pars in the plow frame.
80 or 9000 family plow frames carry the plow bottoms decently and essentially adjust the same. If you can find any number on any plow frame part, it will help identify the plow frame for sure, same thing for plow bottoms which were sold separately from the plow frames.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orange knight Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 7:23pm
I correct myself. I just looked in the book and it is eather a 9000 or a 80 series wheel type.
952-290-1063
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2012 at 11:48pm
Without the bent spring trip side plates, it looks more like an 80 than a 9000 from the illustrations in my plow frames manual, but parts don't look like anything in my book, those bars at an angle between the plow beams up by the hitch.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 12:44am
The 80 seres has the top beam bolted on top as a add on and the 9000 the beam is part of the main frame .
