WD45 distributor trouble
dallypost View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dallypost Quote  Post ReplyReply Direct Link To This Post Topic: WD45 distributor trouble
    Posted: 19 Apr 2012 at 9:45pm
I have a WD45 that has completely discharges the battery after just a few hours of use. This tractor was converted to a 12 volt system and now has an ignition switch.  In probing the system, I noticed that the ignition and accessory terminals all short directly to ground when the key is in the run position. I disconnected one component at a time until the short disappeared. What I found is that the coil terminal on the distributor is shorted directly to ground. So now I am wondering, can this distributor be rebuilt or is there a source where I can buy one.
Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2012 at 9:57pm
Why does the distributor need to be rebuilt?  MACK
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2012 at 10:03pm
The problem has nothing to do with your distributor.
Ian View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2012 at 10:09pm
What they are saying is the distributor is internally grounded, that's normal. If it is discharging the battery while running it is not charging properly.  did you test the voltage at the battery with it off and with it running?
1980 AC 616
1958 AC D14
1960 AC D14
1987 Cub 1204
1982 Cub 682
1974 Cub 154 Lo-Boy (SOLD)
Hauler: 1998 Dodge Ram2500 Cummins
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2012 at 10:15pm
Coil or the Ignition switch could be the culprit!
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2012 at 10:55pm
The coil terminal on the dist would always be shorted to ground when the points are closed. Sounds like your alt isn't working. Put a volt meter across the battery with the engine running at half throttle or more and see what it reads. Should be about 14 volts. The distributor is not your problem. Open the points and your dead short to ground will go away.
