diesel 170 intake question
jmm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmm Quote  Post ReplyReply Direct Link To This Post Topic: diesel 170 intake question
    Posted: 16 Apr 2012 at 4:30pm
hello,
on the intake of my 170's intake manifold is a port of some kind with what looks like a connection point for a wire.  Also, I'm not sure if this should be the way it looks, but a line runs to a bulb in the engine return line.  Can anyone give me an idea if (1) this is correct, and (2) what the purpose for this peice is?
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 4:36pm
It is the pre-heat system that Perkins used. I haven't had one that worked yet.....
ALLIS EXPRESS!
This year:
jmm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jmm Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 4:38pm
and I suppose you've had a few, from the pictures i've seen.  I did see a factory plugged hole on the dash.  Is that what it is for? and... the fuel bypass job? my fuel return line broke, so I figured on bypassing it, and the fuel bulb ( I'm guessing that it has a small restriction to push fuel to the preheat).  thanks for the reply
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2012 at 4:45pm
I think it is supposed to work off of the ignition switch, turn all the way clockwise, then release. Someone said you should hear a "poof" or see some smoke out of the muffler, but the one I think might work doesn't do that. It does seem to start easier if I click the switch a few times.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2012 at 7:07am
Hold the switch until you hear it ignite. It heats the fuel that is in it until it burns causing a small fire in manifold.   MACK
This page was generated in 0.049 seconds.
