d15 II electric issues
JERRYH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JERRYH Quote  Post ReplyReply Direct Link To This Post Topic: d15 II electric issues
    Posted: 15 Apr 2012 at 7:27am
My starter button and ignition  seem to check out ok using multi-tester. However, when I try to connect the negative cable, I get a sound from the starter.  I have rechecked the wires.  They seem to be connected properly.  Any ideas?  Thanks.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2012 at 9:22am
If there is no voltage coming out of the switch to the small wire on the solinoid, but the starter induces when the battery is connected then you have a solinoid that has welded the contacts together. You might take a wrench and smack the solinoid and get it unstuck to varify but replacement of the solinoid is needed as it will do it again.
Yea, I can fix that.....
This page was generated in 0.016 seconds.
